solar powered water
IoT Projects
A Solar-Powered Water Monitoring System
Water is the single most important element for our health and environment. What can we do to preserve it? Monitoring its quality is a good start. Be it in a swimming pool, an agricultural crop, a municipal water facility or a remote well in Africa, preserving clean water can help both reduce unnecessary waste and benefit our health.
THE CHALLENGE
Water quality measurement can be expensive and time-consuming. This is because its parameters are not only physical but also chemical and biological, requiring some of them to be sampled and analyzed at laboratories.
Even though there are more than 30 parameters in water, our challenge was to develop an online monitoring system under these premises:
Simple: Can be built by a non-technical user
Stable: Can be left unattended and charge itself through solar energy
Low-cost (under $200 USD): We integrate commercial hardware and software tools to measure a basic set of parameters that, analyzed in context, can give a sense of the water quality, namely: pH, ORP (Oxidation-Reduction Potential) and Temperature.
You could easily be able to extend this project to measure other parameters like Conductivity or Dissolved Oxygen; just purchase the respective probes and connect them to the analog inputs of the Board.
Although we used a Seeeduino Stalker Kit, you can use your Microcontroller board of choice.
To begin solving problems with the Internet of Things today, simply create an Ubidots account and effortlessly send your data to the Ubidots IoT Application Development Platform to develop, visualize, and deploy your Problem Solving Application today!
