[SOLVED] Changing previous values of a derived variable
Hi all,
I have been gathering data from a derived variable that I realized I made a mistake in calculating.
I corrected the equation in the derived variable however only the most recent values are showing the now correct values. The values I collected/calculated before I found/corrected my mistake are still the same.
Is there any way to correct my historic values as well?
Thank You
Dear @zferrie,
You are able to recalculate the values of a derived variable using the recalculate button located at the end of the header inside the variable desired to be recalculated.
Dibujo%20sin%20t%C3%ADtulo(1)
@mariahernandez
Thank You!
We are here to help! :wink:
