[SOLVED] Compilation error
HI, I am trying to upload example “publish”, but i get this error message.
f:\Arduino\libraries\Ubidots_MQTT_for_ESP8266\src\UbidotsESPMQTT.cpp: In member function 'bool Ubidots::wifiConnection(char*, char*)':
f:\Arduino\libraries\Ubidots_MQTT_for_ESP8266\src\UbidotsESPMQTT.cpp:196:1: warning: no return statement in function returning non-void [-Wreturn-type]
  196 | }
Используем библиотеку Ubidots_MQTT_for_ESP8266 версии 1.1 из папки: f:\Arduino\libraries\Ubidots_MQTT_for_ESP8266
Используем библиотеку pubsubclient-master версии 1.99.1 из папки: f:\Arduino\libraries\pubsubclient-master
Используем библиотеку ESP8266WiFi версии 1.0 из папки: C:\Users\olscr\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.0\libraries\ESP8266WiFi
exit status 1
Ошибка компиляции для платы Generic ESP8266 Module.
full message in the file
error .txt (57.8 KB)
I fixed it. U need download libraries from github, not other sites.
pubsubclient
ubidots-mqtt-esp
Good luck)
Hi @olscraft,
Thank you for sharing the solution with the community.
