Connect Particle Photon directly with Ubidot Cloud platform
Rather than using the particle cloud, I want to send the value directly to the Ubidot cloud platform using Particle photon, I am trying to analyse the data of Altimeter I2C module https://store.ncd.io/product/ms5803-02ba-altimeter-with-24-bit-analog-to-digital-converter-i2c-mini-module/ for measuring pressure values.
But I need to store the values and find out the average after every test run in my smartphone.
For doing this kind of stuff, your advice will be much appreciated.
Greetings, please refer to this article: https://help.ubidots.com/connect-your-devices/connect-a-particle-device-to-ubidots-over-tcpudp
Hey, thanks for your reply can you tell instead of using through get or post method is it possible to use the data via HTTP client or JSON parsing method ?
#4
Greetings, the library implements our TCP protocol estandar due to its lightweight package size, if you wish to use HTTP instead, you will have to adapt any of our HTTP examples to be implemented using the Particle TCP client.
