[SOLVED] Finding min, max not working
I need to find the min/max value of a variable for further calculation, this gives me odd results.
Lets say I want the max. within the last 7 days.
So I create a rolling window with “max”, “every 7 days”, starting from date ‘today - 7days’.
Instead of getting now the max values I get odd results, but the max.
I need this value somehow to make percentage calculations in a derived variable.
Is there any solution for this?
Thanks Sam
Hi @universam,
We are looking into helping you, will get back to you once we have an answer.
all the best,
Catalina M.
Hi @universam,
I just check the rolling window and it works fine, please take a look what I’m doing:
1- Create Rolling window Max
2- Create Rolling window Min
I’m posting a value to TestRolling
They look like this because I only have one value
I post a min value 72
Here you can see the value of the rolling window max of the variable TestRolling
I post a max value 347
Here you can see the value of the rolling window min of the variable TestRolling
Catalina M.
thank you @kath for your efforts to explain, appreciate this.
Not sure why it does not work for my setup. I will start from scratch again.
Thanks!
Sam
Perfect @universam
Hi @kath
Sorry to say, but it is clearly broken in my config. While I can reproduce your example fine, in my real data this is not working as expected.
At the beginning of the data series I have a high value, this one I want to retrieve. But there is no way to ‘catch’ this value. So as example the data series is 3 days old, but even if I specify 7 days interval for MAX value it is not catched, but some smaller, newer values are taken. Indeed it is ‘catched’ once, but immediately overwritten by a smaller number- Makes no sense to me. I tried it several times with different data series.
Feel free to check my account to shed light into it.
Thank you
Sam
Hi @kath
Unfortunately, there is really a bug in that function if you are setting a longer period. It is impossible to get a max value over a period of lets say 7 days.
So creating this rolling window, max over 7 days gives following result, you can clearly see this makes no sense, it should stay on 51!
This is the data source:
Please have a look at that!
Thank you
Sam
I noticed that min/max is not working ok when widget is added. After editing it again it works ok.
Somehow it is set to Last value after creating it.
Best regards
Hi @universam @sampi,
We will reproduce the issue and inform you once we have an answer.
kath :relaxed:
Hi @universam,
Could you check the time range please ? y look that is not the same
Rolling window
Datasource
kath
Hi @kath
Sure I just recreated the rolling window as a Max of 7 days.
The source:
Then I created the Max rolling window over 7 days, clearly it should display something around 17, right!?
Here is then the result of the max rolling window over 7 days:
makes no sense, right
