How to display the Bar Graph from udidots in Android?
I am trying to display the bar graph from the Variable value of Speed Here is initial output
14 PM
& Here is my code…
public class ChartFragment extends Fragment {
private String API_KEY = "";
private String tempVarId = "";
private String humVarId = "";
private static final SimpleDateFormat sdf = new SimpleDateFormat("hh");
// UI reference
/* private LineChart tempChart;*/
private BarChart humChart;
public ChartFragment() {  }
@Override
public void onCreate(Bundle savedInstanceState) {
@Override
public View onCreateView(LayoutInflater inflater, ViewGroup container,
    // Inflate the layout for this fragment
    View v = inflater.inflate(R.layout.fragment_chart, container, false);
/*    tempChart = (LineChart) v.findViewById(R.id.chartTemp);*/
    humChart = (BarChart) v.findViewById(R.id.chartPress);
  /*  initChartTemp(tempChart);*/
    initChartBar(humChart);
    // Pressure
    ( new UbidotsClient() ).handleUbidots(humVarId, API_KEY, new UbidotsClient.UbiListener() {
        @Override
        public void onDataReady(List<UbidotsClient.Value> result) {
            Log.d("Chart", "======== On data Ready ===========");
            List<BarEntry> entries = new ArrayList();
            List<String> labels = new ArrayList<String>();
            for (int i=0; i < result.size(); i++) {
                BarEntry be = new BarEntry(result.get(i).value, i);
                entries.add(be);
                Log.d("Chart", be.toString());
                // Convert timestamp to date
                Date d = new Date(result.get(i).timestamp);
                // Create Labels
                labels.add(sdf.format(d));
            BarDataSet lse = new BarDataSet(entries, "Speed");
            lse.setDrawValues(false);
            lse.setColor(Color.BLUE);
            BarData bd = new BarData(labels, lse);
            humChart.setData(bd);
            Handler handler = new Handler(ChartFragment.this.getActivity().getMainLooper());
            handler.post(new Runnable() {
                @Override
                public void run() {
                    humChart.invalidate();
    return v;
@Override
public void onAttach(Context context) {
    super.onAttach(context);
@Override
public void onDetach() {
    super.onDetach();
private void initChartTemp(LineChart chart) {
    chart.setTouchEnabled(true);
    chart.setDrawGridBackground(true);
    chart.getAxisRight().setEnabled(false);
    YAxis leftAxis = chart.getAxisLeft();
    leftAxis.setAxisMaxValue(100F);
    leftAxis.setAxisMinValue(0F);
    leftAxis.setStartAtZero(true);
    leftAxis.setAxisLineWidth(1000);
    leftAxis.setDrawGridLines(true);
    // X-Axis
    XAxis xAxis = chart.getXAxis();
    xAxis.resetLabelsToSkip();
    xAxis.setPosition(XAxis.XAxisPosition.BOTTOM);
    xAxis.setDrawGridLines(true);
private void initChartBar(BarChart chart) {
    leftAxis.setAxisMaxValue(300F);
    leftAxis.setStartAtZero(false);
    leftAxis.setAxisLineWidth(2);
    // X-Axis
I want the actual output as below…
Uploading…50 PM
Hello @HULK,
For the using of charts with Android, we recommend you to use AndroidChart.
For more information about Ubidots, reference to the Ubidots REST API Reference.
