Is "0.0" an invalid number?
I’m getting errors from my Particle webhooks: “A valid number is required.”
I suspect it may be from sending a variable value that is 0.0, however that would be strange since it is a valid JSON payload. Is this the case?
Greetings, 0.0 is a valid float number as you can see in the image below:
imagen
From your error trace, I suspect that you are not building a JSON that fits theUbidots API, can you share your payload for further analysis?
