Is this link correct for show data from start date and end date .?
Hallo, is this correct link for show data range with link? please anyone help.
if wrong, how the correct answer.? thank you.
http://things.ubidots.com/api/v1.6/variables/{VAR_ID}/values/?start=1522106718342&end=1522051894473
Screenshot_10
Hi there @fahrizal06008, your endpoint structure to retrieve data in a data range is correct and because of that you are not gettings errors from the server.
why the output not like this .? is can show data range beetwen start and end from that link.? in picture below i delete ‘end’ timestamp.
http://things.ubidots.com/api/v1.6/variables/VAR_ID/values/?start=1522052314555
Result
Screenshot_11
#4
Greetings, if you do not get any dot’s information in your request it means that your date range does not have data, make sure that you are setting properly the start and end timestamps.
