Map Trace Widget
There is a bug/unwanted behavior in the Map Trace widget whereby when the trace exits one side of the map the trace draws a line back to where it enters again.
For example, I track the International Space Station and get a nice sinusoidal trace as it passes from left to right across the map. But when it leaves the map on the right there is a straight line drawn back to the left where it once again starts its journey. It should not draw this straight line.
Thank you
