[SOLVED] MKR1000 send two values only
Hello, I am using MKR1000, The device send only twice to the platform and stops,
I am uploading the values of DHT11 sensor.
THE CODE:
#include <UbidotsArduino.h>
# include <SPI.h>
# include <WiFi101.h>
#include "DHT.h"
#define DHTPIN 2
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
#define ID "ID-variable"                        //variable ID
#define TOKEN "TOKEN"         // Profile Token
char ssid[] = "NAME" ;     //wifiname
char pass[] = "PASSWORD" ;    //wifipass
int status = WL_IDLE_STATUS;
void setup(){
  Serial.println("DHTxx test!");
  dht.begin();
  while (status != WL_CONNECTED){
    Serial.print("Attempting to connect to SSID: ");
    Serial.println(ssid);
    status = WiFi.begin(ssid, pass);
     delayMicroseconds(500);  //wait
void loop(){
  // Wait a few seconds between measurements.
  delay(1500);
  // Reading temperature or humidity takes about 250 milliseconds!
  // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
  float h = dht.readHumidity();
  // Read temperature as Celsius (the default)
  float t = dht.readTemperature();
  // Read temperature as Fahrenheit (isFahrenheit = true)
  float f = dht.readTemperature(true);
  // Check if any reads failed and exit early (to try again).
  if (isnan(h) || isnan(t) || isnan(f)) {
    Serial.println("Failed to read from DHT sensor!");
    return;
  // Compute heat index in Fahrenheit (the default)
  float hif = dht.computeHeatIndex(f, h);
  // Compute heat index in Celsius (isFahreheit = false)
  float hic = dht.computeHeatIndex(t, h, false);
  Serial.print("Humidity: ");
  Serial.print(h);
  Serial.print(" %\t");
  Serial.print("Temperature: ");
  Serial.print(t);
  Serial.print(" *C ");
  Serial.print(f);
  Serial.print(" *F\t");
  Serial.print("Heat index: ");
  Serial.print(hic);
  Serial.print(hif);
  Serial.println(" *F");
  client.add(ID, h);
  client.sendAll();
This is the output, it stops sending to server in the third time
Please upgrade the firmware
Attempting to connect to SSID: ATT3mIQ5fU
Humidity: 51.00 % Temperature: 21.00 *C 69.80 *F Heat index: 20.49 *C 68.88 *F
The full HTTP is:
POST /api/v1.6/collections/values/?force=true HTTP/1.1
Host: things.ubidots.com
User-Agent: Arduino-WiFi/1.1
X-Auth-Token: A1E-Gn1r5fJQmKqcFjFb87xQsjPL91AVOr
Connection: close
Content-Length: 59
[{“variable”: “5b588bc2c03f97391580bee5”, “value”:51.00}]
The TCP socket is opened
HTTP/1.1 200 OK
Server: nginx
Date: Thu, 26 Jul 2018 04:52:10 GMT
Transfer-Encoding: chunked
Connection: close
Vary: Accept-Encoding
Vary: Cookie
Allow: POST, OPTIONS
16
[{“status_code”: 201}]
0
Humidity: 52.00 % Temperature: 21.00 *C 69.80 *F Heat index: 20.51 *C 68.92 *F
The full HTTP is:
Connection: close
Content-Length: 59
[{“variable”: “5b588bc2c03f97391580bee5”, “value”:52.00}]
HTTP/1.1 200 OK
Server: nginx
Date: Thu, 26 Jul 2018 04:52:12 GMT
Connection: close
Vary: Cookie
16
0
Humidity: 53.00 % Temperature: 21.00 *C 69.80 *F Heat index: 20.54 *C 68.97 *F
The full HTTP is:
Connection: close
Content-Length: 59
[{“variable”: “5b588bc2c03f97391580bee5”, “value”:53.00}]
The full HTTP is:
Connection: close
Content-Length: 59
Dear user,
Regrettably the library used “UbidotsArduino” is deprecated. Please refer to the repository to check the warning message related to the deprecation of the library.
In order to work with your Device and Ubidots, you should use an Arduino WiFi library supported by your device and handle a WebClient example in order to verify if the device is able to reach out internet properly. Once you are able to handle a sample request you should modify it by following the Ubidots REST API Reference.
I hope this would help you!
