Hi to all!
I´m starting my first MQTT project and i face a dead end.
I want to collect various sensor data and also control relays by the UBIDOTS Dashboard.
Separatly i can achieve that, i can only publish various topics and also subcribe to various topics.
The problem is when i try to do it all together, my guess is a timming issue on the ESP but i found no where to turn.
Can you help me?
Publishing and subscribing using ESP32
bioshock2k
bioshock2k
#2
* Include Libraries
#include <WiFi.h>
#include <PubSubClient.h>
#include <DHT.h>
//#define WIFISSID "" // Put your WifiSSID here
//#define PASSWORD "" // Put your wifi password here
#define TOKEN "" // Put your Ubidots' TOKEN
#define MQTT_CLIENT_NAME "Random" // MQTT client Name, please enter your own 8-12 alphanumeric character ASCII string;
//it should be a random and unique ascii string and different from all other devices
* Define Constants
//IN
#define PHASE1_LABEL "current1" // Assing the variable label
#define PHASE2_LABEL "current2" // Assing the variable label
#define PHASE3_LABEL "current3" // Assing the variable label
#define TEMP_LABEL "temperature" // Assing the variable label
#define HUMID_LABEL "humidity" // Assing the variable label
//OUT
#define VARIABLE_LABEL_SUB_0 "relay_big" // Assing the variable label
#define VARIABLE_LABEL_SUB_1 "relay_small" // Assing the variable
#define VARIABLE_LABEL_SUB_2 "relay_fan" // Assing the variable
#define DHTTYPE DHT22 // DHT 22 (AM2302), AM2321
uint8_t DHTPin = 4;
#define DEVICE_LABEL "esp32" // Assig the device label
* Define Pins
#define SENSOR0 32 // Set the GPIO12 as SENSOR
#define SENSOR1 35 // Set the GPIO12 as SENSOR
#define SENSOR2 34 // Set the GPIO12 as SENSOR
#define R1 33 // Set the GPIO as RELAY
#define R2 25
#define R3 26
char mqttBroker[] = "things.ubidots.com";
char payload[100];
char topic[150];
// Space to store values to send
char str_sensor1[10];
char str_sensor2[10];
char str_sensor3[10];
char str_temp[10];
char str_humid[10];
const uint8_t NUMBER_OF_VARIABLES = 16; // Number of variable to subscribe to
char * variable_labels[NUMBER_OF_VARIABLES] = {"relay_big", "relay_small", "relay_fan"}; // labels of the variable to subscribe to
float CONTROL1; // Name of the variable to be used within the code.
float CONTROL2; // Name of the variable to be used within the code.
float CONTROL3; // Name of the variable to be used within the code.
float value; // To store incoming value.
uint8_t variable; // To keep track of the state machine and be able to use the switch case.
const int ERROR_VALUE = 65535; // Set here an error value
* Interrupts
//--------------- initialize timer1 16bits ( 2Hz )---------------
* Auxiliar Functions
WiFiClient ubidots;
PubSubClient client(ubidots);
DHT dht(DHTPin, DHTTYPE);
float Temperature;
float Humidity;
void get_variable_label_topic(char * topic, char * variable_label) {
Serial.print("topic:");
Serial.println(topic);
sprintf(variable_label, "");
for (int i = 0; i < NUMBER_OF_VARIABLES; i++) {
char * result_lv = strstr(topic, variable_labels[i]);
if (result_lv != NULL) {
uint8_t len = strlen(result_lv);
char result[100];
uint8_t i = 0;
for (i = 0; i < len - 3; i++) {
result[i] = result_lv[i];
result[i] = '\0';
Serial.print("Label is: ");
Serial.println(result);
sprintf(variable_label, "%s", result);
break;
float btof(byte * payload, unsigned int length) {
char * demo_ = (char *) malloc(sizeof(char) * 10);
for (int i = 0; i < length; i++) {
demo_[i] = payload[i];
return atof(demo_);
void set_state(char* variable_label) {
variable = 0;
for (uint8_t i = 0; i < NUMBER_OF_VARIABLES; i++) {
if (strcmp(variable_label, variable_labels[i]) == 0) {
break;
variable++;
if (variable >= NUMBER_OF_VARIABLES) variable = ERROR_VALUE; // Not valid
void execute_cases() {
switch (variable) {
case 0:
CONTROL1 = value;
digitalWrite(R1,value);
Serial.print("CONTROL1: ");
Serial.println(CONTROL1);
Serial.println();
break;
case 1:
CONTROL2 = value;
digitalWrite(R2,value);
Serial.print("CONTROL2: ");
Serial.println(CONTROL2);
Serial.println();
break;
case 2:
CONTROL3 = value;
digitalWrite(R3,value);
Serial.print("CONTROL3: ");
Serial.println(CONTROL3);
Serial.println();
break;
case ERROR_VALUE:
Serial.println("error");
Serial.println();
break;
default:
Serial.println("default");
Serial.println();
void callback(char* topic, byte* payload, unsigned int length) {
char p[length + 1];
memcpy(p, payload, length);
p[length] = NULL;
String message(p);
Serial.write(payload, length);
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.println("Attempting MQTT connection...");
// Attemp to connect
if (client.connect(MQTT_CLIENT_NAME, TOKEN, "")) {
Serial.println("Connected");
} else {
Serial.print("Failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 2 seconds");
// Wait 2 seconds before retrying
delay(2000);
* Main Functions
void setup() {
Serial.begin(115200);
WiFi.begin(WIFISSID, PASSWORD);
// Assign the pin as INPUT
pinMode(SENSOR0, INPUT);
pinMode(SENSOR1, INPUT);
pinMode(SENSOR2, INPUT);
pinMode(DHTPin, INPUT);
pinMode(R1, OUTPUT);
pinMode(R2, OUTPUT);
pinMode(R3, OUTPUT);
dht.begin(); //Starting DHTT
Serial.println();
Serial.print("Wait for WiFi...");
while (WiFi.status() != WL_CONNECTED) {
Serial.print(".");
delay(500);
Serial.println("");
Serial.println("WiFi Connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
client.setServer(mqttBroker, 1883);
client.setCallback(callback);
void loop() {
if (!client.connected()) {
reconnect();
// Subscribes for getting the value of the control variable in the temperature-box device
char topicToSubscribe_variable_1[200];
sprintf(topicToSubscribe_variable_1, "%s", ""); // Cleans the content of the char
sprintf(topicToSubscribe_variable_1, "%s%s", "/v1.6/devices/", DEVICE_LABEL);
sprintf(topicToSubscribe_variable_1, "%s/%s/lv", topicToSubscribe_variable_1, VARIABLE_LABEL_SUB_0);
Serial.println("subscribing to topic:");
Serial.println(topicToSubscribe_variable_1);
client.subscribe(topicToSubscribe_variable_1);
char topicToSubscribe_variable_2[200];
sprintf(topicToSubscribe_variable_2, "%s", ""); // Cleans the content of the char
sprintf(topicToSubscribe_variable_2, "%s%s", "/v1.6/devices/", DEVICE_LABEL);
sprintf(topicToSubscribe_variable_2, "%s/%s/lv", topicToSubscribe_variable_2, VARIABLE_LABEL_SUB_1);
Serial.println(topicToSubscribe_variable_2);
client.subscribe(topicToSubscribe_variable_2);
char topicToSubscribe_variable_3[200];
sprintf(topicToSubscribe_variable_3, "%s", ""); // Cleans the content of the char
sprintf(topicToSubscribe_variable_3, "%s%s", "/v1.6/devices/", DEVICE_LABEL);
sprintf(topicToSubscribe_variable_3, "%s/%s/lv", topicToSubscribe_variable_3, VARIABLE_LABEL_SUB_2);
Serial.println(topicToSubscribe_variable_3);
client.subscribe(topicToSubscribe_variable_3);
//------Current Sensor value--------
float sensor1 = (3.3*analogRead(SENSOR0))/4096;
float sensor2 = (3.3*analogRead(SENSOR1))/4096;
float sensor3 = (3.3*analogRead(SENSOR2))/4096;
//--------------DHT Sensor------------------
Temperature = dht.readTemperature(); // Gets the values of the temperature
Humidity = dht.readHumidity(); // Gets the values of the humidity
//--------------Uploading Values-------------
sprintf(topic, "%s%s", "/v1.6/devices/", DEVICE_LABEL);
sprintf(payload, "%s", ""); // Cleans the payload
sprintf(payload, "{\"%s\":", PHASE1_LABEL); // Adds the variable label
/* 4 is mininum width, 2 is precision; float value is copied onto str_sensor*/
dtostrf(sensor1, 4, 2, str_sensor1);
dtostrf(sensor2, 4, 2, str_sensor2);
dtostrf(sensor3, 4, 2, str_sensor3);
dtostrf(Temperature, 4, 2, str_temp);
dtostrf(Humidity, 4, 2, str_humid);
sprintf(payload, "{\"");
sprintf(payload, "%s%s\":%s", payload, PHASE1_LABEL, str_sensor1);
sprintf(payload, "%s,\"%s\":%s", payload, PHASE2_LABEL, str_sensor2);
sprintf(payload, "%s,\"%s\":%s", payload, PHASE3_LABEL, str_sensor3);
sprintf(payload, "%s,\"%s\":%s", payload, TEMP_LABEL, str_temp);
sprintf(payload, "%s,\"%s\":%s", payload, HUMID_LABEL, str_humid);
sprintf(payload, "%s}", payload);
Serial.println(payload);
client.publish(topic, payload);
client.loop();
delay(500);
jotathebest
#3
Hi there, the example from this link may serve you as reference to publish and subscribe using the same tcp client. Feel free to adapt it to your needs.
bioshock2k
#4
Thank you it helped and i am now at the end of my project with another hasle, connection problems…
Made a new topic to it
If your curious: ESP32 after 1h disconnects from ubidots and never reconnescts
