[SOLVED] Send variable from slider Ubidots to arduino
Hello, my problem is very simple, but complex, becasuse the information not is clear.
I have a variable “termostato” in a widget “SLIDER”, and y want capture the value in arduino for realice a mathematic operation and display in a variable Metric in a Widget.
My code:
     * Include Libraries
    #include "UbidotsESPMQTT.h"
     * Define Constants
    #define TOKEN "**********" // Your Ubidots TOKEN
    #define WIFINAME "VTR-1967554" //Your SSID
    #define WIFIPASS "tp2qtFpdrrcw" // Your Wifi Pass
    #define DEVICE_LABEL  "dispositivo2"  // Put here your Ubidots device label
    #define VARIABLE_LABEL  "termostato"  // Put here your Ubidots variable label
     * Auxiliar Functions
    int valor; int ID_power;
    int valor0;int valor1;
      Serial.print(topic);
      Serial.print("] ");
      for (int i=0;i<length;i++) {
          Serial.print(" ");
        Serial.print((char)payload[0]);
        Serial.print(" ");
        Serial.print((char)payload[1]);
        Serial.print(" ");
        Serial.print((char)payload[2]);
        Serial.print(" ");
        valor0= payload[0];
        valor1= payload[1];
        valor=payload[0]*87;
        Serial.print(valor);
        Serial.print(" ");
     * Main Functions
      client.ubidotsSetBroker("business.api.ubidots.com"); // Sets the broker properly for the business account
      client.setDebug(false); // Pass a true or false bool value to activate debug messages
      client.begin(callback);
      client.ubidotsSubscribe(DEVICE_LABEL, VARIABLE_LABEL); //Insert the dataSource and Variable's Labels
      if(!client.connected()){
          client.reconnect();
      client.add("valor_matematico", valor); //Insert your variable Labels and the value to be sent
      client.ubidotsPublish("dispositivo2");
my attempt is not successful
Best regards
Angel Royo
Greetings, you should edit your callback function to parse your subscribed variable’s value. For more information, please refer to this post.
I don’t find the solution in that Post…
I await a real solution please.
Thank you
AngelRoyo
Greetings @AngelRoyo, as I told you previously, you should edit your callback function to parse the value that arrives from the subscribed topic, you can find an example here. Please read carefully this guide, there you will find the generalities of the callback function and how to use it.
You can also find an example edited callback function example here.
