Ubidots Community
Show second-level detail on dashboard line chart?
I have an IoT device (power monitor) that runs in-frequently, but sends data at 1-sec intervals in short bursts when it does. So may do nothing for an hour, and then burst 1 dot/sec for 30 secs, then again nothing for several minutes to hours. The total number of dots will be low, but the second-level detail is important to me.
The dots are ingesting correctly and I see in the variable that the individual second-level readings are there. But when I view the data in a line chart (amps v. volts v. watts), either on the variable itself or on a line-chart widget, the only data shown is “Last value”…not the second level detail. I also don’t see the data come in using live-view, again I think only last-value.
Is there a way to show this second-level detail visually, esp when showing multiple values?
[I am on STEM license]
Thx!
