Ubidots Community
[SOLVED] 500 Error When Creating Event
Hi, I’m getting 500 Error - internal server error when creating new event.
Basically I’m trying to set a variable if another variable is inactive for 5 minutes. In this way I’m going to indicate if my device is online or offline.
Please help.
Hi @mykola.lashchuk,
Let me check what happen with the event.
Kath
Hi @kath, did you have a chance to check the issue?
Thank you
The solution will be ready for tomorrow, I will notify you.
Kath
The issue is already solved.
Kath :smiley:
Hi @kath, Thanks a lot, it works now :slight_smile:
