[TO BE SOLVED] LoPy freeze after sending some analog data
I follow this tutorial to connect LoPy to ubidots with MQTT. If I follow exactly I can publish without any problem, but when I change the value into analog pin’s value. The data will have delay even I didnt put any time delay and it will stop publishing after \ after about 5-30mins, the connection will be lost and never reconnect back automatically, I have to reset to make it connect again.
I suspect is the library problem, I have two library code but both also didnt work
first one
import usocket
class Response:
    def __init__(self, f):
        self.raw = f
        self.encoding = "utf-8"
        self._cached = None
    def close(self):
        if self.raw:
            self.raw.close()
            self.raw = None
        self._cached = None
    @property
    def content(self):
        if self._cached is None:
            self._cached = self.raw.read()
            self.raw.close()
            self.raw = None
        return self._cached
    @property
    def text(self):
        return str(self.content, self.encoding)
    def json(self):
        import ujson
        return ujson.loads(self.content)
def request(method, url, data=None, json=None, headers={}, stream=None):
    try:
        proto, dummy, host, path = url.split("/", 3)
    except ValueError:
        proto, dummy, host = url.split("/", 2)
        path = ""
    if proto == "http:":
        port = 80
    elif proto == "https:":
        import ussl
        port = 443
    else:
        raise ValueError("Unsupported protocol: " + proto)
    if ":" in host:
        host, port = host.split(":", 1)
        port = int(port)
    ai = usocket.getaddrinfo(host, port)
    addr = ai[0][-1]
    s = usocket.socket()
    s.connect(addr)
        s = ussl.wrap_socket(s, server_hostname=host)
    s.write(b"%s /%s HTTP/1.0\r\n" % (method, path))
    if not "Host" in headers:
        s.write(b"Host: %s\r\n" % host)
    # Iterate over keys to avoid tuple alloc
    for k in headers:
        s.write(k)
        s.write(b": ")
        s.write(headers[k])
        s.write(b"\r\n")
    if json is not None:
        assert data is None
        import ujson
        data = ujson.dumps(json)
    if data:
        s.write(b"Content-Length: %d\r\n" % len(data))
    s.write(b"\r\n")
    if data:
        s.write(data)
    l = s.readline()
    protover, status, msg = l.split(None, 2)
    status = int(status)
    #print(protover, status, msg)
    while True:
        l = s.readline()
        if not l or l == b"\r\n":
            break
        #print(l)
        if l.startswith(b"Transfer-Encoding:"):
            if b"chunked" in l:
                raise ValueError("Unsupported " + l)
        elif l.startswith(b"Location:") and not 200 <= status <= 299:
            raise NotImplementedError("Redirects not yet supported")
    resp = Response(s)
    resp.status_code = status
    resp.reason = msg.rstrip()
    s.close()
    return resp
def head(url, **kw):
    return request("HEAD", url, **kw)
def get(url, **kw):
    return request("GET", url, **kw)
def post(url, **kw):
    return request("POST", url, **kw)
def put(url, **kw):
    return request("PUT", url, **kw)
def patch(url, **kw):
    return request("PATCH", url, **kw)
def delete(url, **kw):
    return request("DELETE", url, **kw)
2nd one
import usocket
class Response:
        self.raw = f
        self._cached = None
    def close(self):
        if self.raw:
            self.raw.close()
            self.raw = None
        self._cached = None
    @property
    def content(self):
            try:
            finally:
                self.raw.close()
                self.raw = None
        return self._cached
    @property
    def text(self):
    def json(self):
        import ujson
    try:
    except ValueError:
        path = ""
        port = 80
        import ussl
        port = 443
    else:
    if ":" in host:
        port = int(port)
    ai = ai[0]
    s = usocket.socket(ai[0], ai[1], ai[2])
    try:
        s.connect(ai[-1])
        for k in headers:
            s.write(k)
            s.write(b": ")
            s.write(headers[k])
            s.write(b"\r\n")
            assert data is None
            import ujson
            s.write(b"Content-Type: application/json\r\n")
        if data:
        s.write(b"\r\n")
        if data:
            s.write(data)
        l = s.readline()
        #print(l)
        l = l.split(None, 2)
        status = int(l[1])
        reason = ""
        if len(l) > 2:
            reason = l[2].rstrip()
        while True:
            l = s.readline()
                break
            #print(l)
                if b"chunked" in l:
    except OSError:
        s.close()
        raise
    resp = Response(s)
    resp.reason = reason
    return resp
def get(url, **kw):
def put(url, **kw):
The first one no freeze but no data receive in ubidots. second will freeze and disconnect from ubidots after some times.
Dear @Vickyh,
We are going to make a test from our side in order to replicate your issue, based on that we will let you know the behavior presented.
