Using WiFi Shield, send to data ubidatos
I used example for UbidotsSaveValue
Then I get Someting from serial moniter.
first red is SSID / Second red is Token / Third red is VariableID
But I Can’t get any data from Ubidots my Account.
please give me some advice.
thank you.
#include <SPI.h>
#include <WiFi.h>
#include <UbidotsArduino.h>
#define ID  "Your_variable_ID_here"  // Put here your Ubidots variable ID
#define TOKEN  "Your_token_here"  // Put here your Ubidots TOKEN
char ssid[] = "yourNetwork"; //  your network SSID (name)
char pass[] = "secretPassword";    // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0;            // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
void setup(){
    while (!Serial) {
        ; // wait for serial port to connect. Needed for native USB port only
    // check for the presence of the shield:
    if (WiFi.status() == WL_NO_SHIELD) {
        Serial.println("WiFi shield not present");
        // don't continue:
        while (true);
    String fv = WiFi.firmwareVersion();
    if (fv != "1.1.0") {
        Serial.println("Please upgrade the firmware");
    // attempt to connect to Wifi network:
    while (status != WL_CONNECTED) {
        Serial.print("Attempting to connect to SSID: ");
        Serial.println(ssid);
        // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
        status = WiFi.begin(ssid, pass);
        // wait 10 seconds for connection:
        delay(10000);
void loop(){
        float value = analogRead(A0);
        client.add(ID, value);
        client.sendAll();
Hello @TOKUNAGA,
Please, can you make a test using the GET example to discard any hardware issue?
#4
Thank you very much your advice.
I try to your suggestion about Getvalue example. so i think that is properly working.
than I get Some result about your code.
but I can’t still upload data. (using sendvalue example)
#5
I also Found that WiFi Shield work Data Light blinking about GetValue code.
I used to SaveValue code. That time is not working DATA Light.
#6
@TOKUNAGA,
Thanks so much for report the inconvenience… Regrettably at this moment we don’t have the Wi-Fi Shield to make the test with your code to verify exactly where can be the issue, but you can reference to this sample code to send data to Ubidots.
 * Libraries included
#include <WiFi.h>
#include <SPI.h>
 * Constants and objects
/* Assigns the network parameters */
char* WIFI_SSID = "Assign_your_WIFI_SSID_here"; // your network WIFI_SSID (name)
char* WIFI_PASSWORD = "Assign_your_WIFI_PASSWORD_here"; // your network password
/* Assigns the Ubidots parameters */
char const * TOKEN = "Assign_your_Ubidots_TOKEN_here"; // Assign your Ubidots TOKEN
char const * DEVICE_LABEL = "arduino"; // Assign the unique device label
char const * VARIABLE_LABEL_1 = "temperature"; // Assign the unique variable label to publish data to Ubidots (1)
char const * VARIABLE_LABEL_2 = "humidity"; // Assign the unique variable label to publish data to Ubidots (2)
/* Parameters needed for the requests */
char const * USER_AGENT = "ARDUINO";
char const * VERSION = "1.0";
char const * SERVER = "things.ubidots.com";
int PORT = 80;
char topic[700];
char payload[300];
/* initialize the library instance */
WiFiClient client;
 * Auxiliar Functions
void SendToUbidots(char* payload) {
  int i = strlen(payload);
  /* Builds the request POST - Please reference this link to know all the request's structures https://ubidots.com/docs/api/ */
  sprintf(topic, "POST /api/v1.6/devices/%s/?force=true HTTP/1.1\r\n", DEVICE_LABEL);
  sprintf(topic, "%sHost: things.ubidots.com\r\n", topic);
  sprintf(topic, "%sUser-Agent: %s/%s\r\n", topic, USER_AGENT, VERSION);
  sprintf(topic, "%sX-Auth-Token: %s\r\n", topic, TOKEN);
  sprintf(topic, "%sConnection: close\r\n", topic);
  sprintf(topic, "%sContent-Type: application/json\r\n", topic);
  sprintf(topic, "%sContent-Length: %d\r\n\r\n", topic, i);
  sprintf(topic, "%s%s\r\n", topic, payload);
  /* Connecting the client */
  client.connect(SERVER, PORT);
  if (client.connected()) {
    /* Sends the request to the client */
    client.print(topic);
    Serial.println("Connected to Ubidots - POST");
    Serial.println("Connection Failed ubidots - Try Again");
  /* Reads the response from the server */
  while (client.available()) {
    char c = client.read();
    //Serial.print(c); // Uncomment this line to visualize the response on the Serial Monitor
  /* Disconnecting the client */
  client.stop();
 * Main Functions
  while (!Serial) {
  /* Check for the presence of the shield */
      /* don't continue */
      while (true);
  /* Attempt to connect to Wifi network */
      Serial.println(WIFI_SSID);
      /* Connect to WPA/WPA2 network. Change this line if using open or WEP network */
      status = WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
      /* Wait 10 seconds for connection */
      delay(10000);
  /* Reads sensors values */
  char* temperature = analogRead(A0);
  char* humidity = analogRead(A1);
  String temp_value = String(temperature);
  String hum_value = String(humidity);
  /* Builds the payload - {"temperature":25.00,"humidity":50.00} */
  sprintf(payload, "{\"");
  sprintf(payload, "%s%s\":%s", payload, VARIABLE_LABEL_1, temp_value.c_str());
  sprintf(payload, "%s,\"%s\":%s", payload, VARIABLE_LABEL_2, hum_value.c_str());
  /* Calls the Ubidots Function POST */
  SendToUbidots(payload);
  /* Prints the data posted on the Serial Monitor */
  Serial.println("Posting data to Ubidots");
  Serial.print("Temperature: ");
  Serial.println(temp_value);
  Serial.print("Humidity: ");
  Serial.println(hum_value);
As you know I don’t have the board to make the test and ensure the code works properly, but you shouldn’t have any issue with, please let me know how it goes.
I hope this can help you to solve your issue.
#7
Thank you for your advice.
I try to your code.
Then I try first your code that send two value and I little change your code to send one value. i use both. result is below.
From your code I got some error.
and got this message from serial monitor
I don’t know why I got upgrade the firware message.actually i already done firmware upgrade. and I tested many Wi-Fi example.
and This time not got any result from both ubidots and Serial monitor.
Then I try send one value . make change little from your code.
I got same error like two value case (your code).
and This time not got a firmware upgrade message. but this case can’t see proper data from serial monitor.
you can see serial monitor data. and Also I can’t get a data from ubidots.
I used below code about one value case.
#include <WiFi.h>
#include <SPI.h>
char* WIFI_SSID = "a"; // your network WIFI_SSID (name)
char* WIFI_PASSWORD = "a"; // your network password
char const * TOKEN = "a"; // Assign your Ubidots TOKEN
int PORT = 80;
char topic[700];
char payload[300];
WiFiClient client;
  client.stop();
 * Main Functions
  while (!Serial) {
      while (true);
      delay(10000);
#8
@TOKUNAGA,
Please, uncomment this line to be able to visualize the response from Ubidots and let me know what you get.
#9
I try to your advice… but i also got same result. result is below
I used Below code. thanks a lot.
#include <WiFi.h>
#include <SPI.h>
char const * TOKEN = ""; // Assign your Ubidots TOKEN
char const * DEVICE_LABEL = "data"; // Assign the unique device label
int PORT = 80;
char topic[700];
char payload[300];
WiFiClient client;
  client.stop();
 * Main Functions
  while (!Serial) {
      while (true);
      delay(10000);
