How control relay arduino with android?
Hi, i am rizal.
i got problem about controll relay from android. i want every time user click button relay on .
i have ubidots account, if i press widget button from things.ubidots.com relay connected perfectly. but my problem if i control via android.i search in this forum and i try every code but nothing. please help.
i use android studio. for get value from ubidots to android , i already done.
my code for send data to ubidots :
@Override
        setContentView(R.layout.activity_pemupukan);
        ImageButton siram_pupuk = findViewById(R.id.buttonpemupukan);
        mPupukLevel = (TextView) findViewById(R.id.jarak_pupuk);
        status_pupuk = (TextView) findViewById(R.id.textView4);
        siram_pupuk.setOnClickListener(new View.OnClickListener()
            @Override
            public void onClick(View v)
                Toast.makeText(getApplicationContext(), "ON", Toast.LENGTH_SHORT).show();
                SendApiUbidots sendApi = new SendApiUbidots();
                sendApi.execute();
        new ApiUbidots().execute(5);
        //return null;
 public class SendApiUbidots extends AsyncTask<Integer, Void, Void>{
        private final String API_KEY = "YOUR API-KEY";
        private final String VARIABLE_ID_2 = "YOUR VARIABLE";
        @Override
        protected Void doInBackground(Integer... params) {
            Variable switchVariable = apiClient.getVariable(VARIABLE_ID_2);
            switchVariable.saveValue(params[0]);
            return null;
Screenshot_44Screenshot_45
Greetings @fahrizal06008 ,
The Ubidots JAVA library is outdated and we are working in its update (it was tested for android 5.0 and below). If you are getting errors I advise you to create your own request that fits our REST API to retrieve your variable’s value using apiClient or another HTTP requests library for Java.
