[SOLVED] How to create/modify bar-charts?
Hi there,
a few days ago I created a mixed chart with two variables:
Var1 Line Chart
Var2 Bar Chart
Now I’d like to make some adjustments and can’t find how to select the chart type anymore. I tried to create a new line chart, add a variable and the only variable options I get are ‘aggregation method’ and ‘sample period’.
Also, when I’m editing an existing bar-chart (line chart widget), there’s no way to change the chart type (e.g., from bar to line).
I’m on a Professional subscription.
Am I overlooking something?
Thanks, Valentin
Hello @tintsch,
We have identified this sudden bug where the type of chart options in the Line chart widget have been hidden. Ubidots Dev team is already aware and a ticket has been issued.
As soon as this bug is fixed and deployed to production, I’ll let you know.
–David
Hello @tintsch,
Just wanted to let you know that this bug has been fixed and deployed to production. You should be able to select the type of chart: line, dots, line or step, as well as the right or left Y-Axis.
–David
