Thank you so much @Metavix for your help. I changed the “source name” to “source tag” it work perfectly. I’m getting value 5.0
But, why does it print out "
Client connected
Particle/1.1|LV|4cOonYcioTF2JgwHldR75bfOGYgh9X|36003d000247343339373536:onoff|end
Receiving TCP transaction of 4 bytes.
OK|5End of TCP transaction.End o
Can You please fix this in your newest version of library?
The entire data is a debug method to search if any user got a problem, it is better than show nothing. But if you prefer i could change that to show only the float response. Im happy to solve your problem, thank you so much for your patient
Thank you so much @Metavix for your help. My problem has solved now. I’ve tried the 2.05,2.06,2.1.0 and 2.1.1 library not of these working with function ubidots.getValueWithDatasource()
Only The 2.1.2 is working properly without any issues. Hope you can make a note to anyone else know.
@ouchboy
It is very strange. Green led is infinite loop, the code is stuck. But led cyan is connected to the GSM network. When you upload the code the led has another color before the cyan? or only green and then cyan?
