@ouchboy try to add ubidots.setDatasourceName("box");
under Serial.begin(115200);
No success.
Result:
-Serial unresponsive
-Led breathing cyan
interesting thing is that after i upload this particular code I can no longer flash OTA.
this only happens with getting values, sending values is working fine.
edit: thanks for the help guys. I wouldn’t bother you but im flying blind on this one.
@ouchboy
It is very strange. Green led is infinite loop, the code is stuck. But led cyan is connected to the GSM network. When you upload the code the led has another color before the cyan? or only green and then cyan?
well i have to put the device on listening mode. so starting from there
- blinking blue
-magenta
-flashing led
-solid cyan for 2-3 seconds
-breating cyan
upload over serial. I can’t upload OTA after i put the code in.
@ouchboy could you try to upgrade the electron firmware? or the electron firmware is in its latest version?
@ouchboy Last time, I have this problem was by using the 2.1.2 library, you probably need to try to use this library and see if this work for you.
ok.
so upgraded the firmware ( to 0.5.1). now im at @faweiz situation. only 0.0 on putty
should i go down to 2.1.2?
did go down stuck at 0.0 ( I don’t get package received like @faweiz did
No. Never downgrade the lib version. Now do you could upload the code via OTA?
yes. now i can flash OTA. (with bth new and old library)
@ouchboy I think i found the problem, i will try to fix it and test it in my electron. it’s a new error that before never happend. Give some minutes and i will fix it.
Metavix
