[SOLVED] Subscribed but cant get data
hello everyone, i am having this issue trying to use ubidots to trigger 3 switches in a ESP 8266.
i run my code, esp connects in the network, connects to ubidots MQTT, subscribe to the topics, but, when i change values with the dashboard the callback function is never called.
this is the code running in the ESP 8266
#include "UbidotsESPMQTT.h"
 * Define Constants
#define TOKEN "XXXXXXXXXXXXXXXXXXXX" // Your Ubidots TOKEN
#define WIFINAME "XXXXX" //Your SSID
#define WIFIPASS "XXXXXXXX" // Your Wifi Pass
int sensorPin = A0;
int ledPin = D5;
int relayPin = D3;
int state;
int lightState;
 * Main Functions
  client.setDebug(true);
  client.begin(callback);
  client.ubidotsSubscribe("stuffboxrele", "relayone"); //Insert the dataSource and Variable's Labels
  client.ubidotsSubscribe("stuffboxrele", "relaytwo"); //Insert the dataSource and Variable's Labels
  client.ubidotsSubscribe("stuffboxrele", "relaytree"); //Insert the dataSource and Variable's Labels
  if(!client.connected()){
      client.reconnect();
 * Auxiliar Functions
  Serial.print(topic);
  Serial.print("] ");
  for (int i=0;i<length;i++) {
   if ((char)payload[0]=='1'){
    digitalWrite(relayPin, HIGH);
   else if ((char)payload[0]=='0'){
    digitalWrite(relayPin, LOW);
it is the example code for subscribing ubidots mqtt with my data, this should work as the variables seems to be working in the dashboard.
after running this code i get the following data from the serial.(DEBUG)
`⸮⸮n⸮...........WiFi connected
IP address:
192.168.100.177
entra
Attempting MQTT connection...connected
Subscribed to:
/v1.6/devices/stuffboxrele/relayone/lv
Subscribed to:
/v1.6/devices/stuffboxrele/relaytwo/lv
Subscribed to:
/v1.6/devices/stuffboxrele/relaytree/lv
^^^just that and nothing more, even when i change variables value trhough the dashboard, i dont receive any data.
am I doing anything wrong?
Hi there, if you own an industrial account, please follow this example.
Let me know if it works.
this is the exemple i used, I own a trial account for instance
Hi there, not, in your first post you are not using the example that I provided you. You need to set the broker to business.api.ubidots.com or industrial.api.ubidots.com:
client.ubidotsSetBroker("business.api.ubidots.com");
Please refer to the line 35 of the example that I previously shared with you.
