Been working on this for days. Tried many examples to subscribe to change state on an output using a switch on the dash. Everything seems to work except the output doesn’t change. Hardware and wiring is good.
I am obviously missing something simple. Thank You for any ideas!
John
Attempting MQTT connection…connected
Subscribed to:
/v1.6/devices/esp8266/temperature/lv
publishing to TOPIC:
JSON dict: {“stuff”: [{“value”: 10.00}]}
Subscribed to:
* Include Libraries
#include "UbidotsESPMQTT.h"
* Define Constants
#define TOKEN "xxxx" // Your Ubidots TOKEN
#define WIFINAME "x" // Your SSID
#define WIFIPASS "xxx" // Your Wifi Pass
* Auxiliar Functions
Serial.print(topic);
Serial.print("] ");
for (int i=0;i<length;i++) {
if ((char)payload[0]=='1'){
digitalWrite(16, HIGH);
else{
digitalWrite(16, LOW);
* Main Functions
client.ubidotsSetBroker("industrial.api.ubidots.com");
client.begin(callback);
pinMode(16, OUTPUT);
client.ubidotsSubscribe("esp8266","temperature"); //Insert the dataSource and Variable's Labels
if(!client.connected()){
client.reconnect();
client.add("stuff", 10);
client.ubidotsPublish("esp8266"); // was "source1" in example???????
delay (15000);
