Hi, I am getting this error 429 Too Many Requests You have sent too many requests in a given amount of time. when i click in to login of ubidots.
Hello @Sush,
Could you please tell me your Ubidots username to verify your account?
When you encounter the 429 error, it indicates that you need to reduce the frequency of data transmission to your devices. Remember, each token in your account permits a maximum of 5 requests per second. If you exceed this limit for a certain duration, you will receive this error.
Alejandro
How can I reduce the frequency of data transmission from the arduino device? How can I check if it is maximum of 5 requests per second as the application is not logging in as it is showing 429 too many requests error.
Is there any possibility of checking via user to know the exact issue…
Hello @Sush,
Could you please specify where exactly you are encountering the 429 error? Additionally, could you identify which devices are generating this error? I am unable to see any devices with recent activity in your account.
Hi, I am encountering 429 error when I click on to the login of Ubidots application immediately when I click I am encountering this 429 error.
Could you please share with me any image showing the error?
