Can I use properties to create syntentic variables?
I receive raw data from devices which needs to be calibrated.
Each device has a unique calibration constant.
I would like to store the calibration constant as a property of the device.
I then want to create a syntentic variable which references the raw data and property.
How can I do this?
i.e.
Synthetic = property1 x raw + property 2
Greetings @ShockWave, right now it is not possible to use device properties as input values to a SV, this is because device properties may be not only numbers but strings. What you would do is to create a raw variable in your device type that stores your calibration constant and to create a SV related with that variable.
Ok thank you.
How do I edit the value of the raw variable?
I have been looking in the docs and it can be linked to a slider or switch. I would want to edit it with a few significant figures so a slider would be no good.
#4
Hi there, probably the example two of this article may work for your use-case.
