After selecting TTS plug-in and the Type is automatically defined, can I define new Types for each device type I use?
Hello Marlan,
Thank you for reaching out to our Community Forum.
The Plugin creates the Devices while automatically assigning the Device Type, however, after that you may change the Device Type for the Devices as required. That is, the Plugin shouldn’t reassign the TTS Device Type once another Device Type has been assigned.
Sebastián
Thanks Sebastian. This is great news.
I believe then that a BEST practices MIGHT be to define new TTS TYPES things like “battery low alert voltage” and other metadata that would go with specific device types.
I was wondering for end nodes that you might want to send DOWNLINKS to, maybe the downlink instruction could be defined in the TYPE and then it could be accessed in the EVENT WebHook.
I think the TYPE can do much more than people think. Any advice would be welcome.
(You can mark solved if you want.)
Thx,
Marlan
Is there a way to duplicate the TTS Device Type so I don’t have to create one-by-one?
