I hope you can help me with my project. I want to publish the values of three variables. All of them appear of the dash board. However, two of them take long period of time to change. I would like them to change one every 2 seconds.
I included my could if you could just help me, I would be very greatful.
#include <Arduino.h>
- Include Libraries
#include <WiFi.h>
#include <PubSubClient.h>
// the values that I want to sent to the cloud, but they are as strings.
String a;
String T;
String I;
String V;
String t;
float v;
float r;
float i;
// port and pins on 2ed bord
#define RXp2 16
#define TXp2 17
#define WIFISSID “maree123” // Put your WifiSSID here
#define PASSWORD “ohsh1022” // Put your wifi password here
#define TOKEN “BBFF-Xr4faUcK8Ylp997Bufs1ax0axIMRsK” // Put your Ubidots’ TOKEN
#define MQTT_CLIENT_NAME “RandomName” // MQTT client Name, please enter your own 8-12 alphanumeric character ASCII string;
//it should be a random and unique ascii string and different from all other devices
- Define Constants
#define VARIABLE_LABEL_1 “Temprature” // Assing the variable label
#define VARIABLE_LABEL_SUBSCRIBE “Temp” // Assing the variable label
#define DEVICE_LABEL “esp” // Assig the device label
//**********var2
#define VARIABLE_LABEL_2 “Current” // Assing the variable label
#define VARIABLE_LABEL_SUBSCRIBE “I” // Assing the variable label
#define VARIABLE_LABEL_3 “volt” // Assing the variable label
#define VARIABLE_LABEL_SUBSCRIBE “volt” // Assing the variable label
char mqttBroker[] = “things.ubidots.com”;
char payload1[500];
char topic1[128];
//char topic2[50];
//char topic3[50];
char topicSubscribe[200];
char str_sensor1[128];
- Auxiliar Functions
WiFiClient ubidots;
PubSubClient client(ubidots);
void reconnect() {
// Loop until we’re reconnected
while (!client.connected()) {
// Attemp to connect
Serial.println("Connected");
client.subscribe(topicSubscribe);
Serial.print("Failed, rc=");
Serial.print(client.state());
char p[length + 1];
memcpy(p, payload, length);
p[length] = NULL;
String message(p);
- Main Functions
// Assign the pin as INPUT ???/
Serial2.begin(9600, SERIAL_8N1, RXp2, TXp2);
Serial.print(“Wait for WiFi…”);
Serial.print(".");
delay(500);
Serial.println("");
Serial.println(“WiFi Connected”);
client.setCallback(callback);
sprintf(topicSubscribe, “/v1.6/devices/%s/%s/lv”, DEVICE_LABEL, VARIABLE_LABEL_SUBSCRIBE);
if (!client.connected()) {
reconnect();
a=Serial2.readString();
V= a.substring(17,23);
v=V.toFloat();
T=a.substring(4,9);
r=T.toFloat();
I=a.substring(30,34);
i=I.toFloat();
sprintf(topic1, “%s%s”, “/v1.6/devices/”, DEVICE_LABEL);
sprintf(payload1, “%s”, “”); // Cleans the payload
sprintf(payload1, “{”%s":",VARIABLE_LABEL_1);
dtostrf(r, 4, 2, str_sensor1);
sprintf(payload1, “%s {“value”: %s}}”, payload1, str_sensor1);
client.publish(topic1, payload1);
sprintf(payload1, “{”%s":",VARIABLE_LABEL_2);
dtostrf(i, 4, 2, str_sensor1);
sprintf(payload1, “{”%s":",VARIABLE_LABEL_3);
dtostrf(v, 4, 2, str_sensor1);
Serial.print("V= ");
Serial.print(v );
Serial.print(" T= ");
Serial.print( r );
Serial.print(" I= ");
Serial.println( i) ;
Serial.println(“Publishing data to Ubidots Cloud”);
