Code failure when sending MQTT Ubidots Package
Hello friends, how are you? I need help with the following item: When sending temperature data to Ubidots, a crash occurs in the code, using either arduino ide classic or arduino 2.0. The same code works normally using the arduino WEB.
Comments:
1- I have already replaced all the libraries and all are with their original versions.
2- Why the arduino web works and the arduino IDE classic and 2.0 don’t if the code and libraries are the same?
3- When I use only the temperature reading part in the code, the code and device work normally, but when I insert the publication for the ubidots, the code presents the failure described below.
��…WiFi connected
IP address:
192.168.1.172
entra
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
Exception (0):
epc1=0x40201639 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
stack>>>
THE CODE:
  Include Libraries
#include "UbidotsESPMQTT.h"
#include <OneWire.h>
  Define Constants and Instances
#define TOKEN "XXX" // Your Ubidots TOKEN
#define WIFINAME "XXX" // Your SSID
#define WIFIPASS "XXX" // Your Wifi Pass
#define MQTTCLIENTNAME "XXX" // Your MQTT Client Name, it must be unique so we recommend to choose a random ASCCI name
#define Pin D3
int temp;
OneWire ourWire(Pin);
DallasTemperature sensors(&ourWire);
  Auxiliar Functions
  Serial.print(topic);
  Serial.print("] ");
  Main Functions
  sensors.begin();
  client.begin(callback);
  if (!client.connected()) {
    client.reconnect();
  //Prepare the sensor for reading
  temp = sensors.getTempCByIndex(0);
  Serial.print(sensors.getTempCByIndex(0));
  //Read and print the temperature in Celsius
  client.add("temperature", temp);
  //Insert your variable Labels and the value to be sent
  Serial.println("_Celcius");
  client.ubidotsPublish("XXX");
  delay(3000);
Hello @CAEGRUBR ,
Thank you for your message.
I recently tested the MQTT library that you’re using in an ESP8266 with the classic Arduino IDE and everything was working as expected. Are you presenting the same problem with another MQTT library for the ESP8266? Because as I can see, the problem could be related to that library due to you were able to connect to your WiFi network.
I’ll be attentive to your comments.
Best Regards,
– Leonardo
