hi , i new here and novice in python language. I already tried multiple times by combining 2 coding for installing machine in the device. can you help me ? im using adc3008 in myproject. here my coding that i tried success in python output shell but failed install at ubidots device management .
import time
import requests
import math
import random
import os
import RPi.GPIO as GPIO
import json
GPIO.setmode(GPIO.BCM)
DEBUG = 1
TOKEN = “BBFF-8dtojEOmf8VC4ywZyQJ7u0J1owPJPd” # Put your TOKEN here
DEVICE_LABEL = “machine4” # Put your device label here
VARIABLE_LABEL_1 = “pressure” # Put your first variable label here
def readadc(adcnum, clockpin, mosipin, misopin, cspin):
if ((adcnum > 7) or (adcnum < 0)):
return -1
GPIO.output(cspin, True)
GPIO.output(clockpin, False)
GPIO.output(cspin, False)
commandout = adcnum
commandout |= 0x18
commandout <<= 3
for i in range(5):
if (commandout & 0x80):
GPIO.output(mosipin, True)
else:
GPIO.output(mosipin, False)
commandout <<= 1
GPIO.output(clockpin, True)
adcout = 0
for i in range(12):
adcout <<= 1
if (GPIO.input(misopin)):
adcout |= 0x1
adcout >>= 1
return adcout
SPICLK = 18
SPIMISO = 23
SPIMOSI = 24
SPICS = 25
GPIO.setup(SPIMOSI, GPIO.OUT)
GPIO.setup(SPIMISO, GPIO.IN)
GPIO.setup(SPICLK, GPIO.OUT)
GPIO.setup(SPICS, GPIO.OUT)
potentiometer_adc = 0;
last_read = 0
tolerance = 5
while True:
pressure_changed = False
pressure = readadc(potentiometer_adc, SPICLK, SPIMOSI, SPIMISO, SPICS)
pressure_adjust = abs(pressure - last_read)
if ( pressure_adjust > tolerance ):
pressure_changed = True
if ( pressure_changed ):
set_volume = pressure / 10.24
set_volume = round(set_volume)
set_volume = int(set_volume)
print ('Volume = {volume}%' .format(volume = set_volume))
set_vol_cmd = 'sudo amixer cset numid=1 -- {volume}% > /dev/null' .format(volume = set_volume)
os.system(set_vol_cmd) # set volume
def build_payload(variable_1):
payload= {variable_1: set_volume}
last_read = pressure
time.sleep(0.5)
return payload
def post_request(payload):
# Creates the headers for the HTTP requests
url = “http://industrial.api.ubidots.com”
url = “{}/api/v1.6/devices/{}”.format(url, DEVICE_LABEL)
headers = {“X-Auth-Token”: TOKEN, “Content-Type”: “application/json”}
# Makes the HTTP requests
status = 400
attempts = 0
while status >= 400 and attempts <= 5:
req = requests.post(url=url, headers=headers, json=payload)
status = req.status_code
attempts += 1
time.sleep(1)
# Processes results
if status >= 400:
print("[ERROR] Could not send data after 5 attempts, please check \
your token credentials and internet connection")
return False
print("[INFO] request made properly, your device is updated")
return True
def main():
payload = build_payload(VARIABLE_LABEL_1,)
print("[INFO] Attemping to send data")
print("[INFO] finished")
if name == ‘main’:
while (True):
main()
time.sleep(1)
DELAY = 1 # Delay in seconds
for my own coding without substitute in example code;
import time
import os
import json
DEBUG = 1
read SPI data from MCP3008 chip, 8 possible adc’s (0 thru 7)
return -1
GPIO.output(clockpin, False) # start clock low
GPIO.output(cspin, False) # bring CS low
commandout = adcnum
commandout |= 0x18 # start bit + single-ended bit
commandout <<= 3 # we only need to send 5 bits here
for i in range(5):
else:
commandout <<= 1
adcout = 0
# read in one empty bit, one null bit and 10 ADC bits
for i in range(12):
adcout <<= 1
adcout |= 0x1
adcout >>= 1 # first bit is 'null' so drop it
return adcout
change these as desired - they’re the pins connected from the
SPI port on the ADC to the Cobbler
SPICLK = 18
SPIMISO = 23
SPIMOSI = 24
SPICS = 25
set up the SPI interface pins
10k trim pot connected to adc #0
last_read = 0 # this keeps track of the last potentiometer value
tolerance = 5 # to keep from being jittery we’ll only change
# volume when the pot has moved more than 5 ‘counts’
while True:
# we’ll assume that the pot didn’t move
# read the analog pin
# how much has it changed since the last read?
set_volume = pressure / 10.24 # convert 10bit adc0 (0-1024) trim pot read into 0-100 volume level
set_volume = round(set_volume) # round out decimal value
set_volume = int(set_volume) # cast volume as integer
# save the potentiometer reading for the next loop
# hang out and do nothing for a half second
time.sleep(0.5)
output_string = ‘{“Volume = {volume}%” : Volume = {volume}%}’
output_dict = json.load(output_string)
print(json.dumps(output_dict,indent=1,sort_keys= True))
please can you help me ??
