Hi all,
Just wandering if it is possible to connect more than one hardware / controller to a single STEM account. I tried to connect two hardware to same STEM account. Once the connection of 2nd hardware is established, the connection of fist hardware dropped.
JZ
Good day @robocreek,
You can connect up to 3 devices with 10 variables for free. Can you please let us know the following:
- Which hardware was the one you connect first that stopped transmitting data?
- Which protocol are the devices using to connect to your STEM account?
- How often do they send data?
- Are you using one of our libraries? If so, which one?
- Are you using the same token in both of these devices?
Also, please refer to the following article to learn more about the included features in STEM.
Hi Isalogi,
Thanks for the reply.
We’re using two identical hardware setup to send data to Ubitdots:
DHT11 (humidity/temperature sensor) >> microbit v2 >> ESP8266 AT command >> wifi/Ubidots
If the second hardware is turned on and sending data to Ubidtos, the connection to the first hardware will lost.
We are using MQTT protocol.
Every two minutes.
No, we’re not using your existing libraries. We wrote the microbit library to send data via the ESP8266 AT command.
If only one hardware is turned on, it can run for few hours continuously without any issue.
Yes, we use same token in both hardwares. However, we set it to different device and variable name
JZ
Thank you @robocreek for all the information. The only thing you need to have in mind is the daily quota of dots in which is 1 request per second per token across all devices, and up to 4,000 dots per day. You can use a token per device instead of one to avoid hit the request per second limit.
Please let me know if you need additional assistance.
If you are using MQTT, make sure that both devices uses a different MQTT clientID as the broker allows just one connection per clientID.
