Ubidots Community
Connection of Arduino Nano 33
  • Libraries included
#include <SPI.h>
#include <WiFiNINA.h>
#include <avr/dtostrf.h>
  • Constants and objects
#define DEVICE_LABEL “arduino-nano-33”
#define TOKEN “BBFF-EGuBSGUOgag02kB4gv2VBfo0P7G073”
char const * VARIABLE_LABEL_1 = “sensor”;
char const *SERVER=“industrial.api.ubidots.com”;
const int HTTPPORT= 443;
char const *AGENT=“Arduino Nano 33 IoT”;
char const *HTTP_VERSION = " HTTP/1.1\r\n";
char const *VERSION =“1.0”;
char const *PATH= “/api/v1.6/devices/”;
char const * SSID_NAME = “Liew’s iPhone”; // Put here your SSID name
char const * SSID_PASS = “1234567890”; // Put here your password
int status = WL_IDLE_STATUS;
WiFiSSLClient client;
  • Auxiliar Functions
void printWiFiStatus() {
// print the SSID of the network you’re attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your board’s IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print(“signal strength (RSSI):”);
Serial.print(rssi);
Serial.println(" dBm");
void getResponseServer() {
Serial.println(F("\nUbidots’ Server response:\n"));
while (client.available()) {
char c = client.read();
Serial.print(c); // Uncomment this line to visualize the response on the Serial Monitor
void waitServer() {
int timeout = 0;
while (!client.available() && timeout < 5000) {
timeout++;
delay(1);
if (timeout >= 5000) {
  Serial.println(F("Error, max timeout reached"));
  break;
void sendData(char* payload) {
int contentLength = strlen(payload);
/* Connecting the client */
if (client.connect(SERVER, HTTPPORT)) {
Serial.println("connected to server");
client.print(F("POST "));
client.print(PATH);
client.print(DEVICE_LABEL);
client.print(F("/"));
client.print(HTTP_VERSION);
client.print(F("Host: "));
client.print(SERVER);
client.print(F("\r\n"));
client.print(F("User-Agent: "));
client.print(AGENT);
client.print(F("X-Auth-Token: "));
client.print(TOKEN);
client.print(F("Connection: close\r\n"));
client.print(F("Content-Type: application/json\r\n"));
client.print(F("Content-Length: "));
client.print(contentLength);
client.print(F("\r\n\r\n"));
client.print(payload);
Serial.print(F("POST "));
Serial.print(PATH);
Serial.print(DEVICE_LABEL);
Serial.print(F("/"));
Serial.print(HTTP_VERSION);
Serial.print(F("Host: "));
Serial.print(SERVER);
Serial.print(F("\r\n"));
Serial.print(F("User-Agent: "));
Serial.print(AGENT);
Serial.print(F("X-Auth-Token: "));
Serial.print(TOKEN);
Serial.print(F("Connection: close\r\n"));
Serial.print(F("Content-Type: application/json\r\n"));
Serial.print(F("Content-Length: "));
Serial.print(contentLength);
Serial.print(F("\r\n\r\n"));
Serial.print(payload);
waitServer();
getResponseServer();
/* Disconnecting the client */
client.stop();
  • Main Functions
//Initialize serial and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// check for the WiFi module:
if (WiFi.status() == WL_NO_MODULE) {
Serial.println("Communication with WiFi module failed!");
// don't continue
while (true);
// attempt to connect to WiFi network:
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(SSID_NAME);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(SSID_NAME, SSID_PASS);
// wait 10 seconds for connection:
delay(10000);
Serial.println(“Connected to wifi”);
printWiFiStatus();
void loop(){
char payload[200];
char str_val_1[30];
/4 is the total lenght of number,maximum number accepted is 99.99/
float value = analogRead(A0);
dtostrf(value, 4, 2, str_val_1);
sprintf(payload, “%s”,"");
sprintf(payload, “{”");
sprintf(payload, “%s%s”:%s", payload, VARIABLE_LABEL_1, str_val_1);
sprintf(payload, “%s}”, payload);
//Send the payload to Ubidots
sendData(payload);
This is the code I am using. However, I am not using industrial version of ubidots. Instead, I am using STEM version of ubidots. Is there anything that I need to change?
This is the output results.
16:05:26.974 → Attempting to connect to SSID: Liew’s iPhone
