Hi, I´m trying to send data to Ubidots, but when I connect my ESP32S to serial port I have the message “Could not connect to the server, please check your network and your firewall rules” and the datas doesnt send.
this is my code, please help me.
#include <Wire.h>
#include <LCD.h>
#include <LiquidCrystal_I2C.h>
#include <WiFi.h>
#include <Ubidots.h>
//Credenciales WiFi
#define WIFI_SSID "INTERNET_CNT YEPEZ"
#define WIFI_PASSWORD "Titokeluckyfer12345"
//Variables reseteo de funcion millis
long previousMillis = 0;
//Control de motor
int ON = 14; //BOTON DE ON/OF
int lect_M = 0;
int MOTOR = 27;
//Control de dispensador (Rele e IR)
int lect_IR = 0;
const int pinIR = 25;
int bomba = 26;
int cont = 0;
int seg = 0;
//Variables sensor Ultrasónico (Medidor de cantidad)
volatile const int Trigger = 0;
volatile const int Echo = 15;
volatile long t = 0; //timepo que demora en llegar el eco
volatile long d = 0; //distancia en centimetro
volatile int porcent = 0;
int lect_ULTRA = 0;
const int ON_ULTRA = 19; //Switch para presentar cantidad restante del envase
//Variable de la alarma (buzzer)
int buzzer = 33;
//Credenciales Proyecto Ubidots
#define UBIDOTS_TOKEN "BBFF-73VWnb4z2xgXxb5FtmkBGNcmvqL2uP"
#define DEVICE_LABEL "dispensador-1"
Ubidots ubidots (UBIDOTS_TOKEN, UBI_HTTP);
//Constantes del servidor Ubidots
#define LAB_CANT "canti"
#define LAB_VASOS "vasos"
#define LAB_pH "pH"
#define I2C_ADDR 0x27
LiquidCrystal_I2C lcd(I2C_ADDR,2, 1, 0, 4, 5, 6, 7);
//Pines para motor
pinMode (MOTOR, OUTPUT);
pinMode(ON, INPUT);
//Pines para dispensador (Rele e IR)
pinMode(pinIR , INPUT);
pinMode(bomba, OUTPUT);
//Pines para el sensor Ultrasónico
pinMode(Trigger, OUTPUT); //pin como salida
pinMode(Echo, INPUT); //pin como entrada
pinMode(ON_ULTRA, INPUT);
digitalWrite(Trigger, LOW);//Inicializamos el pin con 0
//Pin buzzer (alarma)
pinMode(buzzer, OUTPUT);
lcd.begin(16,2);
lcd.setBacklightPin(3,POSITIVE);
lcd.setBacklight(HIGH);
lcd.setCursor(0, 0);
lcd.home();
lcd.clear();
//Configuración WiFi
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
Serial.print("Conectado a la red: ");
while (WiFi.status() != WL_CONNECTED){
Serial.print(".");
delay(250);
Serial.print("MAC: ");
Serial.println(WiFi.macAddress());
//Inicializa conexión hacia FIREBASE
Serial.println("Conectando a Ubidots...");
dots.wifiConnect(WIFI_SSID, WIFI_PASSWORD);
dots.setDebug(true);
//Código del motor
lect_M = digitalRead(ON);
if (lect_M == HIGH){
on_MOTOR();
else{
off_MOTOR();
//Código de Rele e IR
lcd.print(" Esperando....");
lcd.setCursor(0, 1);
lcd.print(" Acerque el vaso");
lect_IR = digitalRead(pinIR); //lectura digital de pin
if (lect_IR == LOW){
delay(25);
vaso_DETECT();
if (seg >= 20){
retire_VASO();
CONTADOR_VASOS();
if (seg >= 20 || lect_IR == HIGH) {
esperando_VASO();
delay(400);
//Para el sensor Ultrasónico
datos_ULTRA();
lect_ULTRA = digitalRead(ON_ULTRA);
if (lect_ULTRA == HIGH){
delay(25);
muestra_CANTIDAD();
//Alarma envase casi vacío
if (porcent <= 40){
llenar_ENVASE();
* FUNCIONES A SER LLAMADAS POR LAS CONDICIONES
* VOID LOOP MÁS PRESENTABLE Y VACÍO
//Encendido y apgado del motor
void on_MOTOR(){
delay(25);
digitalWrite(MOTOR, LOW);
delay(25);
void off_MOTOR(){
delay(25);
digitalWrite(MOTOR, HIGH);
delay(25);
//Detección y llenado del vaso
void vaso_DETECT(){
digitalWrite(bomba, HIGH);
lcd.backlight();
lcd.display();
lcd.clear();
if (currentMillis - previousMillis > 1000){
previousMillis = currentMillis;
seg ++;
lcd.print(" Aprox. 13 seg. ");
lcd.print("Ha(n) pasado: ");
lcd.print( seg);
if (seg > 20){
lcd.setCursor(9, 1);
lcd.print("00");
//Función conteo de vasos
void CONTADOR_VASOS(){
if (lect_IR != HIGH){
cont++;
ubidots.add(LAB_VASOS, cont);
bool buffersent = false;
buffersent = dots.send(DEVICE_LABEL);
//Función retirar el vaso
void retire_VASO(){
digitalWrite(bomba, LOW);
lcd.print(" Retire el vaso");
lcd.noDisplay();
lcd.noBacklight();
//Función detectando vaso
void esperando_VASO(){
seg = 0;
delay(25);
delay(20);
//Lectura del sensor Ultrasónico
void datos_ULTRA(){
digitalWrite(buzzer, LOW);
digitalWrite(Trigger, HIGH);
delay(10); //Enviamos un pulso de 10us
t = pulseIn(Echo, HIGH); //obtenemos el ancho del pulso
d = t/58.2; //escalamos el tiempo a una distancia en cm
porcent = map (d, 4, 26, 100, 0);
millis(); //Reatardo para que el sensor recolecte bien los datos
//Muestra cantidad del envase
void muestra_CANTIDAD(){
lcd.backlight();
lcd.display();
lcd.clear();
cont++;
ubidots.add(LAB_CANT, porcent);
lcd.setCursor(0,0);
lcd.print(" Cant. restante");
lcd.setCursor(6,1);
lcd.print(porcent);
lcd.print(" %");
delay(500);
//Lectura <= 10% del envase
void llenar_ENVASE(){
lcd.backlight();
lcd.display();
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(6,1);
lcd.print(porcent);
lcd.print(" %");
delay(500);
digitalWrite(buzzer, HIGH);
delay(300);
delay(50);
