Good morning, I need help.
I am using ESP8266 as a pulse counter
based on a code i found in your community with analog input D0.
Which for lack of my own knowledge is difficult for me to configure the synthetic variable in the ubidots panel, I upload an image to explain in detail:
I want the count setting to be every 8 hours, but apparently I am doing something wrong.
- Include Libraries
#include “UbidotsESPMQTT.h”
- Define Constants
#define TOKEN “BBFF-164QkjoSlO5ywd5fyfsgzO8gT” // Your Ubidots TOKEN
#define WIFINAME “INFINC251” //Your SSID
#define WIFIPASS “Oom1G” // Your Wifi Pass
- Auxiliar Functions
Serial.print(topic);
Serial.print("] ");
for (int i=0;i<length;i++) {
- Main Functions
//client.ubidotsSetBroker(“industrial.api.ubidots.com”); // Sets the broker properly for the industrial account
client.begin(callback);
if(!client.connected()){
client.reconnect();
float value1 = analogRead(A1);
client.add(“temperature”, value1);
client.ubidotsPublish(“my-new-device”);
float value1 = analogRead(A0);
