[SOLVED] Custom Styling for Widgets
Is there a published list of objects that can be customized in the custom styling for stock widgets? I couldn’t find any resources apart from this webpage… https://help.ubidots.com/en/articles/3189001-application-branding-custom-styles-for-your-dashboards-and-widgets
Hi there, the available customized property for widgets is the header, which is the keyword to modify the widget’s header. You can use any CSS property inside the header section or out of it.
