Thank you @qntfy, I received your message.
I have a few questions, but first, let me confirm that we are able to take only one reading per day, scheduled at a specific time. In this case, the set time is 6 AM.
However, it’s not clear to me what you want to do with the original variable you sent me privately. I understand that the variable reports data approximately every 15 minutes, but what exactly do you want to calculate at 6 AM? Are you looking to calculate the sum of the previous day’s values, take an average, or perhaps read the first or last value of the day? There are several possibilities here.
My question arises because it’s important to clarify what you want to do with the original raw variable. The good news is that, regardless of the operation you choose, we can use the same structure to retrieve a single reading per day at 6 AM.
This article explains how to configure it using a specific date range and an offset:
Analytics: Synthetic Variables Basics | Ubidots Help Center
For instance, if you want to generate only one value per day, you can use a date range of ‘24H’ or ‘1D’.
Next, we can add an offset to the expression to specify the starting hour for generating the first value. For example, by setting the offset to 6, the variable will generate the first value at 6 AM. Here’s a good example:
In this example, we’re calculating the sum of a variable every 8 hours, starting at 6 AM. With an ‘8H’ range, it will generate a value at 6 AM, another at 2 PM, and the last one at 10 PM. The cycle will then repeat, with the next value generated at 6 AM the following day.
In our case, if we add an offset = 6, and a range of “24H”, it will generate only one value per day at 6 AM.
Please take a look and let me know if you have any questions.
Alejandro
