ERROR ubidots.reconnecting
Hello I am trying to publish the state of a variable in Ubidotos from Node-Red, but it is never published.
stays in ubidots.reconnecting.
Hello @astrmedia,
Can you please provide additional details as for example, the configuration of the Node, the version of the nodes or any other information that can help troubleshooting?
–David
Hi, i have the same problem. i am trying using the ubidots_out node with a simple button. i have checked all the settings but its not possible to connect with the ubidots page and at the bottom of the node it say error connecting and ubidots.reconnecting
Hello @mateo203
I would like to confirm which token you are using for the connection. I will send you a private message to discuss this, and then I will return to this chat with the details.
Alejandro
Hello @alejomora7 , I have the same problem and I can’t solve it. When I created the node, it connected, but then ubidots.reconnecting and error.connecting appeared. It never connected again.
Please, could you help me solve this problem? I am using ubidots in a project.
Hello @ARamirezC,
Some days ago, we identified an error with our Ubidots Out node in Node-RED. Specifically, when you first create the node, configure your token, and deploy the flow, it works perfectly. However, if you then make any subsequent changes to that node (such as changing the token or device label) and deploy again, a persistent reconnecting error will appear.
We are still working on a permanent solution. In the meantime, my recommendation is that if you need to make any changes to the node, please recreate it from scratch: delete the existing node, add a new one, configure it, and then deploy the changes. This workaround should ensure a stable connection.
I will be attentive if you have any question.
