Hello i’m having problem compiling this coding . I don’t know what mistakes i did , So i’m trying to sync my sensor data to firebase but the problem turns out like this.
this is the error message
this is where the problem but i don’t know how to solve it
//esp32 with wifi library
#include <WiFi.h>
#include <WiFiClient.h>
#include <esp_now.h>
#include <esp_wifi.h>
//firebaseArduino library
#include <FirebaseESP32.h>
//dht11 library
#include <DHT.h>
//define dht sensor
#define DHTTYPE DHT11
//insert wifi credential
const char* ssid = "nasran65@unifi";
const char* password = "nasran65";
//define rtdb
#define FIREBASE_HOST "projectfirebase-688c5-default-rtdb.asia-southeast1.firebasedatabase.app"
//define rtdb secret key
#define FIREBASE_AUTH "EXpcv1T6ggWyGLusYX2nABy9cAVAqvpNxVODw1NF"
//define dht sensor pin
const int DHTPin = 5;
// Initialize DHT sensor.
DHT dht(DHTPin, DHTTYPE);
dht.begin();
WiFi.begin(ssid, password);
Serial.println("Connecting to wifi...");
delay(500);
Serial.println("wifi connected");
Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH);
pinMode(23,INPUT);
digitalWrite(23,LOW);
Serial.print("RSSI: ");
Serial.print(WiFi.RSSI());
Serial.println("dBm");
long rssiValue = WiFi.RSSI();
//store data into firebase rtdb
Firebase.setFloat("Sensor/RSSI",rssiValue);
Firebase.getFloat("Sensor/RSSI");
//read humidity
float h = dht.readHumidity();
//read temperature (in Celsius)
float t = dht.readTemperature();
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t)) {
Serial.println("Failed to read from DHT sensor!");
return;
//Computes temperature values in Celsius
float hic = dht.computeHeatIndex(t, h, false);
Serial.print("Temperature: ");
Serial.print(t);
Serial.println("°C");
Serial.print("Humidity: ");
Serial.print(h);
Serial.println("%");
//store dht11 data into firebase rtdb
Firebase.setFloat("Sensor/TEMP",t);
Firebase.getFloat("Sensor/TEMP");
Firebase.setFloat("Sensor/HUMID",h);
Firebase.getFloat("Sensor/HUMID");
// store pir data into firebase rtdb
Firebase.setFloat("Sensor/PIR",PIR);
Firebase.getFloat("Sensor/PIR");
Firebase.setFloat("Sensor/LDR",ldr);
Firebase.getFloat("Sensor/LDR");
if(digitalRead(23)==HIGH) {
Serial.println("Somebody is here.");
else {
Serial.println("Nobody.");
int ldr = analogRead( A0 );
Serial.println("LDR : " + String(ldr) );
