I have the problem described on the tittle.
Reading some similar problems and comparing my code to theirs i cannot see what can i be doing wrong.
It´s weird beacuse if i manually restart the esp32 it will connect again normally.
Thanks in advance from anyone who reads this.
HERES THE CODE:
* Include Libraries
#include <WiFi.h>
#include <PubSubClient.h>
#include <DHT.h>
#include <EmonLib.h>
#include "chewing.h"
EnergyMonitor emon1;
EnergyMonitor emon2;
EnergyMonitor emon3;
filter chew;
* Include WIFI Networks
I DELETED MY WIFI INFORMATION
#define TOKEN "XXXX" // Put your Ubidots' TOKEN
#define MQTT_CLIENT_NAME "Random" // MQTT client Name, please enter your own 8-12 alphanumeric character ASCII string;
//it should be a random and unique ascii string and different from all other devices
* Offsets
#define sensor1_offset 0.35
#define sensor2_offset 0.35
#define sensor3_offset 0.25
* Define Constants
//IN
#define PHASE1_LABEL "current1" // Assing the variable label
#define PHASE2_LABEL "current2" //Assing the variable label
#define PHASE3_LABEL "current3" // Assing the variable label
#define TEMP_LABEL "temperature" // Assing the variable label
#define HUMID_LABEL "humidity" // Assing the variabl3e label
//OUT
#define VARIABLE_LABEL_SUB_0 "relay_big" // Assing the variable label
#define VARIABLE_LABEL_SUB_1 "relay_small" // Assing the variable
#define VARIABLE_LABEL_SUB_2 "relay_fan" // Assing the variable
//Temperature Sensor
#define DHTTYPE DHT22 // DHT 22 (AM2302), AM2321
#define DEVICE_LABEL "esp32" // Assig the device label
* Define Pins
#define SENSOR0 34 // Set the GPIO12 as SENSOR
#define SENSOR1 32 // Set the GPIO12 as SENSOR
#define SENSOR2 35 // Set the GPIO12 as SENSOR
#define R1 33 // Set the GPIO as RELAY
#define R2 25
#define R3 26
uint8_t DHTPin = 4;
char payload[100];
char topic[150];
char str_sensor1[10];
char str_sensor2[10];
char str_sensor3[10];
char str_temp[10];
char str_humid[10];
const uint8_t NUMBER_OF_VARIABLES = 16; // Number of variable to subscribe to
char * variable_labels[NUMBER_OF_VARIABLES] = {"relay_big", "relay_small", "relay_fan"}; // labels of the variable to subscribe to
float CONTROL1; // Name of the variable to be used within the code.
float CONTROL2; // Name of the variable to be used within the code.
float CONTROL3; // Name of the variable to be used within the code.
float value; // To store incoming value.
uint8_t variable; // To keep track of the state machine and be able to use the switch case.
const int ERROR_VALUE = 65535; // Set here an error value
// Force EmonLib to use 10bit ADC resolution
#define ADC_BITS 10
#define ADC_COUNTS (1<<ADC_BITS)
* Interrupts
//--------------- initialize timer1 16bits ( 2Hz )---------------
* Auxiliar Functions
WiFiClient ubidots;
PubSubClient client(ubidots);
DHT dht(DHTPin, DHTTYPE);
float Temperature;
float Humidity;
// Set your Static IP address
IPAddress local_IP(192, 168, 1, 184);
// Set your Gateway IP address
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 255, 0);
IPAddress primaryDNS(8, 8, 8, 8); //optional
IPAddress secondaryDNS(8, 8, 4, 4); //optional
void get_variable_label_topic(char * topic, char * variable_label) {
Serial.print("topic:");
Serial.println(topic);
sprintf(variable_label, "");
for (int i = 0; i < NUMBER_OF_VARIABLES; i++) {
char * result_lv = strstr(topic, variable_labels[i]);
if (result_lv != NULL) {
uint8_t len = strlen(result_lv);
char result[100];
uint8_t i = 0;
for (i = 0; i < len - 3; i++) {
result[i] = result_lv[i];
result[i] = '\0';
Serial.print("Label is: ");
Serial.println(result);
sprintf(variable_label, "%s", result);
break;
float btof(byte * payload, unsigned int length) {
char * demo_ = (char *) malloc(sizeof(char) * 10);
demo_[i] = payload[i];
return atof(demo_);
void set_state(char* variable_label) {
variable = 0;
for (uint8_t i = 0; i < NUMBER_OF_VARIABLES; i++) {
if (strcmp(variable_label, variable_labels[i]) == 0) {
break;
variable++;
if (variable >= NUMBER_OF_VARIABLES) variable = ERROR_VALUE; // Not valid
char p[length + 1];
memcpy(p, payload, length);
p[length] = NULL;
String message(p);
//Serial.println(topic); //print relays payload
execute_cases(topic,p[0]);
void execute_cases();
void reconnect();
* Main Functions
//adc1_config_channel_atten(ADC1_CHANNEL_6, ADC_ATTEN_DB_11);
analogReadResolution(ADC_BITS); //Enable 10 bits in emonlib
if (!WiFi.config(local_IP, gateway, subnet, primaryDNS, secondaryDNS)) {
Serial.println("STA Failed to configure");
// Assign the pin as INPUT
pinMode(SENSOR0, INPUT);
pinMode(SENSOR1, INPUT);
pinMode(SENSOR2, INPUT);
pinMode(DHTPin, INPUT);
pinMode(R1, OUTPUT);
pinMode(R2, OUTPUT);
pinMode(R3, OUTPUT);
//Lemon Setup
emon1.current(SENSOR0,30);
emon2.current(SENSOR1,30);
emon3.current(SENSOR2,30);
dht.begin(); //Starting DHTT
Serial.print(".");
delay(500);
Serial.println("");
client.setCallback(callback);
if (!client.connected()) { //Runs once!
reconnect();
// Subscribes for getting the value of the control variable in the temperature-box device
char topicToSubscribe_variable_1[200];
sprintf(topicToSubscribe_variable_1, "%s", ""); // Cleans the content of the char
sprintf(topicToSubscribe_variable_1, "%s%s", "/v1.6/devices/", DEVICE_LABEL);
sprintf(topicToSubscribe_variable_1, "%s/%s/lv", topicToSubscribe_variable_1, VARIABLE_LABEL_SUB_0);
Serial.println("subscribing to topic:");
Serial.println(topicToSubscribe_variable_1);
client.subscribe(topicToSubscribe_variable_1);
char topicToSubscribe_variable_2[200];
sprintf(topicToSubscribe_variable_2, "%s", ""); // Cleans the content of the char
sprintf(topicToSubscribe_variable_2, "%s%s", "/v1.6/devices/", DEVICE_LABEL);
sprintf(topicToSubscribe_variable_2, "%s/%s/lv", topicToSubscribe_variable_2, VARIABLE_LABEL_SUB_1);
Serial.println(topicToSubscribe_variable_2);
client.subscribe(topicToSubscribe_variable_2);
char topicToSubscribe_variable_3[200];
sprintf(topicToSubscribe_variable_3, "%s", ""); // Cleans the content of the char
sprintf(topicToSubscribe_variable_3, "%s%s", "/v1.6/devices/", DEVICE_LABEL);
sprintf(topicToSubscribe_variable_3, "%s/%s/lv", topicToSubscribe_variable_3, VARIABLE_LABEL_SUB_2);
Serial.println(topicToSubscribe_variable_3);
client.subscribe(topicToSubscribe_variable_3);
//------Current Sensor value--------
double sensor1 = emon1.calcIrms(1480);
double sensor2 = emon2.calcIrms(1480);
double sensor3 = emon3.calcIrms(1480);
// -------Offset setting-------------
sensor1 = sensor1 - sensor1_offset;
sensor2 = sensor2 - sensor2_offset;
sensor3 = sensor3 - sensor3_offset;
//---------FILTERTING----------------
sensor1 = chew.chewing_it(sensor1); //FILTERTING
sensor2 = chew.chewing_it(sensor2);
sensor3 = chew.chewing_it(sensor3);
//--------------DHT Sensor------------------
Temperature = dht.readTemperature(); // Gets the values of the temperature
Humidity = dht.readHumidity(); // Gets the values of the humidity
//--------------Uploading Values-------------
sprintf(payload, "{\"%s\":", PHASE1_LABEL); // Adds the variable label
dtostrf(sensor1, 4, 2, str_sensor1);
dtostrf(sensor2, 4, 2, str_sensor2);
dtostrf(sensor3, 4, 2, str_sensor3);
dtostrf(Temperature, 4, 2, str_temp);
dtostrf(Humidity, 4, 2, str_humid);
sprintf(payload, "{\"");
sprintf(payload, "%s%s\":%s", payload, PHASE1_LABEL, str_sensor1);
sprintf(payload, "%s,\"%s\":%s", payload, PHASE2_LABEL, str_sensor2);
sprintf(payload, "%s,\"%s\":%s", payload, PHASE3_LABEL, str_sensor3);
sprintf(payload, "%s,\"%s\":%s", payload, TEMP_LABEL, str_temp);
sprintf(payload, "%s,\"%s\":%s", payload, HUMID_LABEL, str_humid);
Serial.println(payload); //Print payload
delay(500);
void execute_cases(String message, int bi) {
//Serial.print(message[26]); //Show first Letter of topic
if (message[26] == 's'){
variable=0;
if (message[26] == 'b'){
variable=1;
if (message[26] == 'f'){
variable=2;
switch (variable) {
case 0: //Small rig 1 relay
if(bi==48){ //48 == 0 in string 49 == 1
digitalWrite(R1,HIGH);
else{
digitalWrite(R1,LOW);
break;
case 1: //Big Rig 2 relays
if(bi==48){
digitalWrite(R2,HIGH); //Non switching PSU
digitalWrite(R3,HIGH); //MOBO PSU
else{
digitalWrite(R2,LOW);
digitalWrite(R3,LOW);
break;
// case 2: //Fan 1 Relay
// if(bi==48){
// digitalWrite(R3,HIGH);
// else{
// digitalWrite(R3,LOW);
//// Serial.print("CONTROL3: ");
//// Serial.println(bi);
//// Serial.println();
// break;
case ERROR_VALUE:
Serial.println("error");
break;
default:
Serial.println("default");
void reconnect() {
while (!client.connected()) {
// Attemp to connect
Serial.println("Connected");
Serial.print("Failed, rc=");
Serial.print(client.state());
