Greetings from Colombia!
I have trying to send the data for the actual position of my esp32 device to the Ubidots platform, but I could not do it from the Arduino IDE. When the device is running, the platform doesn’t recognize the variable or the position.
PD: Sorry for my bad English.
This is the code that I have used:
#include "UbidotsEsp32Mqtt.h"
const char *UBIDOTS_TOKEN = "****************************";
const char *WIFI_SSID = "********";
const char *WIFI_PASS = "*******";
const char *DEVICE_LABEL = "MyEsp32";
const char *VARIABLE_LABEL = "gps";
const int PUBLISH_FREQUENCY = 5000;
unsigned long timer;
float latitud = 1.23164;
float longitud = -77.29426;
char context[25];
int gps = 1;
* Auxiliar Functions
void callback(char *topic, byte *payload, unsigned int length)
Serial.print(topic);
Serial.print("] ");
for (int i = 0; i < length; i++)
* Main Functions
void setup()
ubidots.setDebug(true);
ubidots.setup();
ubidots.reconnect();
timer = millis();
void loop()
if (!ubidots.connected())
if (abs(millis() - timer) > PUBLISH_FREQUENCY) // triggers the routine every 5 seconds
sprintf(context, "lat=%.2f$lng=%.2f", latitud, longitud);
ubidots.add(VARIABLE_LABEL, 1, context);
Serial.println(context);
timer = millis();
ubidots.loop();
