I am new for ESP32,I am trying connect to server,after AT+CIPSEND=280 it gets bad request like as
+IPD,309:HTTP/1.1 400 Bad Request
Server: nginx/1.16.1
Date: Sat, 05 Jun 2021 10:24:02 GMT
Content-Type: text/html
Content-Length: 157
Connection: close
regards,
Naren
Hello @narendar
Thanks for sharing your issue with the community.
Now, a 400 error means that either the endpoint or body is malformed and so not compatible with the Ubidots’ API. In that sense, can you please share the code lines where you connect to the server and build the payload? It’s likely that the error might be in any of those lines.
–Sergio.
