ESP32, Only one value per variable is published
I am using ESP32 to publish a variable to ubidots, it works but only one value is showed. If I delete the varible and reset the ESP32, the variable is created automaticaly and the first value is showed again.
Any idea?
Thanks,
After a few test, I can confirm that my code is correct and sometimes my ESP32 is able to publishing properly.
I do not have problems with my internet conexion, I think the problem is with Ubidots broker.
