Fisrt Test NodeMcu
I’m just start with Ubidots and NodeMcu, to start, i’m doing the first test of turning on a led, i can connect but i can’t turn the led on or off, you know what it can be?
  • Include Libraries
    #include “UbidotsESPMQTT.h”
  • Define Constants
    #define TOKEN “xxxxxxxxxxx” // Your Ubidots TOKEN
    #define WIFINAME “xxxxx” //Your SSID
    #define WIFIPASS “xxxxxxx” // Your Wifi Pass
  • Auxiliar Functions
Serial.print(topic);
Serial.print("] ");
for (int i=0;i<length;i++) {
if( payload[0] == '0' ){
  digitalWrite(D0,LOW);
else
  digitalWrite(D0,HIGH);
  • Main Functions
// Setup LED pin
pinMode(D0,OUTPUT);
//client.ubidotsSetBroker(“business.ubidots.com”);
client.ubidotsSetBroker(“things.ubidots.com”);
client.begin(callback);
client.ubidotsSubscribe(“esp8266”,“led”); //Insert the dataSource and Variable’s Labels
if(!client.connected()){
client.reconnect();
Hello @thiagoconsales,
Try changing the line
To
client.ubidotsSetBroker(“industrial.api.ubidots.com”);
And of course, make sure the enter a valid TOKEN from your STEM account, and the WiFi credentials. Other than that I don’t see anything else preventing the code from working as you expect.
–David
