Hi, there.
I saw the thread of reading two variables and wanted to create a synchronized chart. However, I am stuck in the place where I created a single graph with two lines. I wonder how to separate like those in the example. Is there any setting I should modify?
Here include the program that I have modified based on the motivation.
seriesOptions = [];
var seriesCounter = 0
var names = [VARIABLE1, VARIABLE2];
//var names = [TEMP1, TEMP2, TEMP3, TEMP4, TEMP5, TEMP6];
var nicenames = ['VARIABLE1', 'VARIABLE2'];
//var nicenames = ['TEMP1', 'TEMP2', 'TEMP3', 'TEMP4', 'TEMP5', 'TEMP6'];
function getDataFromVariable(variable, token, callback) {
var url = 'https://industrial.api.ubidots.com/api/v1.6/variables/' + variable + '/values';
var headers = {
'X-Auth-Token': token,
'Content-Type': 'application/json'
$.ajax({
url: url,
method: 'GET',
headers: headers,
success: function(res) {
callback(res.results);
function createChart() {
var chart = Highcharts.chart('container', {
chart: {
marginLeft: 40, // Keep all charts left aligned
spacingTop: 20,
spacingBottom: 20
title: {
//text: dataset.name,
align: 'left',
margin: 0,
x: 30
credits: {
enabled: false
legend: {
enabled: false
xAxis: {
crosshair: true,
events: {
setExtremes: syncExtremes
labels: {
format: '{value} km'
yAxis: {
title: {
text: null
tooltip: {
positioner: function() {
return {
// right aligned
x: this.chart.chartWidth - this.label.width,
y: 10 // align to title
borderWidth: 0,
backgroundColor: 'none',
pointFormat: '{point.y}',
headerFormat: '',
shadow: false,
style: {
fontSize: '18px'
//valueDecimals: dataset.valueDecimals
series: [{
data: seriesOptions[0],
data: seriesOptions[1],
//type: dataset.type,
//color: Highcharts.getOptions().colors[i],
//fillOpacity: 0.3,
//tooltip: {
// valueSuffix: ' ' + dataset.unit
// repeating function
(function() {
// 1. Call load_seriesOptions passing a callback function,
// which will be called receiving the result from the async operation
console.log("1. function called...")
load_seriesOptions(function(result) {
// 5. Received the result from the async function,
// now do whatever you want with it:
//console.log("5. result is: ", result);
console.log("5. result received");
/* if (chart) {
chart.destroy();
chart = undefined;
createChart()
setTimeout(arguments.callee, 60000);
function load_seriesOptions(callback) {
console.log("2. callback here is the function passed as argument above...")
// 3. Start async operation:
seriesOptions = [];
for (var fieldIndex = 0; fieldIndex < names.length; fieldIndex++) {
var name = names[fieldIndex];
getDataFromVariable(name, TOKEN, function (values) {
console.log("3. start async operation...");
var data = values.map(function(value) {
return [value.timestamp, value.value];
console.log(data)
seriesOptions.push(data); //1 series
if (seriesOptions.length == names.length) {
console.log("4. finished async operation, calling the callback, passing the result...")
// 4. Finished async operation,
// call the callback passing the result as argument
callback(seriesOptions);
* In order to synchronize tooltips and crosshairs, override the
* built-in events with handlers defined on the parent element.
['mousemove', 'touchmove', 'touchstart'].forEach(function(eventType) {
document.getElementById('container').addEventListener(
eventType,
function(e) {
var chart,
point,
i,
event;
for (i = 0; i < Highcharts.charts.length; i = i + 1) {
chart = Highcharts.charts[i];
// Find coordinates within the chart
event = chart.pointer.normalize(e);
// Get the hovered point
point = chart.series[0].searchPoint(event, true);
if (point) {
point.highlight(e);
* Override the reset function, we don't need to hide the tooltips and
* crosshairs.
Highcharts.Pointer.prototype.reset = function() {
return undefined;
* Highlight a point by showing tooltip, setting hover state and draw crosshair
Highcharts.Point.prototype.highlight = function(event) {
event = this.series.chart.pointer.normalize(event);
this.onMouseOver(); // Show the hover marker
this.series.chart.tooltip.refresh(this); // Show the tooltip
this.series.chart.xAxis[0].drawCrosshair(event, this); // Show the crosshair
* Synchronize zooming through the setExtremes event handler.
function syncExtremes(e) {
var thisChart = this.chart;
if (e.trigger !== 'syncExtremes') { // Prevent feedback loop
Highcharts.each(Highcharts.charts, function(chart) {
if (chart !== thisChart) {
if (chart.xAxis[0].setExtremes) { // It is null while updating
chart.xAxis[0].setExtremes(
e.min,
e.max,
undefined,
false, {
trigger: 'syncExtremes'
