Hyy guys i am lokeshwar as of now am working on a project called “water monitoring system” in this am measuring water quality using ph sensor if ph values is greater than 7 i have to display “water has high alkalinity” and if less than 7 i have to show " water is acidic ".So how can i do this.
To achieve this behavior I’d recommend to use the indicator widget and set a color logic in such way that when the value is 7 or higher shows a specific message and other if lower.
@lokeshwar.robo2, yes, from the color logic of the indicator widget you can the set the text and color to display for multiple range of values. Please refer to the below image.
