I’m trying to GET value from Ubidots and pass it to Pushover but for some reason, I can’t get the value and I’m NOT sure how to pass it over to Pushover.
If I use Postman to GET value everything seems to work and I’m getting my value:
Hello, @codev3rt
Thanks for reaching out,
I suggest you place the token in the X-Auth-Token field, even though it works as a query the best practice is to include it as a header.
-Santiago
Hi, thank you for your reply but nothing seems to work with IFTTT.
I tried using X-Auth-Token in different parts of the IFTTT but still no luck.
Obviously it works perfectly fine with Postman:
and Curl:
and here is the IFTTT:
and another example:
and one more:
That is very strange indeed. Have you reached out to IFTTT/Pushover support so they can check on their side? also, Is there any way for you to know what the response of that webhook is when executed?
