Ubidots Community
Manual Input from Mobile Device
Hi @isalogi,
I created a manual input and I am able to change a raw variable I assigned to a device. When I pull the dashboard up on my iPhone and input a manual 4 digit entry (ex. 2002) nothing happens but is says “data sent successfully”. When I enter the same thing from my computer it says “data sent successfully” and it shows up on the device instantaneous. Am I missing something?
Update: The Slider widget works fine from iPhone, the manual input appears to have the bug.
Hi @Backpacker87,
Thank you for letting us know about this situation.
Can you please let me know the mobile browser you are using for accessing Ubidots from your iPhone? in that way we can perform some test and identify if anything is out of place.
@isalogi thank you for your help.
I am using the default Safari.
I am on iPhone Xs running 13.3.1
Hi @Backpacker87,
Thank you for the information.
I will make some tests and come back to you.
Hi @Backpacker87,
I went ahead and made some tests using an iPhone device with Safari iOS 13.4 and I was able to send data as expected using the Manual Input widget. Can you please let me know the Safari version you are using? Additionally, If you can send us a video of the issue will be of great help to identify where is the problem coming from.
Hi @isalogi ,
I have the same problem. I was able to send data when I login to my Ubidots account. However, when I shared my Ubidots Dashboard to the public, the send data function was not working properly although the computer showed that the data sent successfully.
Please advise. Thank you very much.
Hi @stephenwong,
Thank you for letting us know about this. Can you please let me know if this is happening both from mobile and pc? I will review the case and let you know my findings.
Hi Isabel,
Thanks for your quick response.
Yes, it is happening on both the mobile and PC. Manual input only works when I am login to my ubidots account. However, it will not work when I share the dashboard to the public.
Thank you @stephenwong,
We were able to replicate this behavior with the manual input using the Dashboard public link. I’ve already reported with the development team and I will let you know as soon as the solution is ready.
Hi Isabel,
Thank you very much for your help.
