[SOLVED]Map widget not working lately
We have our demo running 24/7
and it worked until recently (days ago). Now the map is not working, but the other widgets are.
We figured it is a temporary problem, but does not seem so. Check the dashboard at
https://industrial.ubidots.com/app/dashboards/public/dashboard/Sh4joR1RDoDaMzVkNONp2lj7X76ubset52H71tjKeAg?nonavbar=true
Hello @gambitcomm,
We identified an issue with devices whose location mode was set to “Auto” and never changed before. For the time being, we applied a change that circumvents that bug and makes the dashboard operational again.
The definitive solution will be deployed during the day.
–David
Seems to work.
Thanks.
The problem is back.
@gambitcomm same dashboard?
yes post must be at least 5 characters
@gambitcomm, can you test again, please? We deployed a hot-fix and so far, it seems to be working from our end.
Your confirmation will be appreciated.
works again.
Would be nice if you had some kind of 24/7 monitoring of your dashboards
to detect bugs. We run 24/7 monitors on our cloud-based simulations with detection
within a minute.
