Tengo un ESP32 conectado a Ubidots a través de protocolo Mqtt. La información que envío desde mi esp32, se muestra perefectamente en el dashboard (widget) de Ubidots, pero cuando intento recibir el estado de un -swich em mi módulo esp32, este valor nunca llega, la función callback, nunca se ejecuta. Gracias por su atención
* Include Libraries
#include "UbidotsEsp32Mqtt.h"
* Define Constants
const char* UBIDOTS_TOKEN = "**********"; // Put here your Ubidots TOKEN
const char* WIFI_SSID = "OSPINA"; // Put here your Wi-Fi SSID
const char* WIFI_PASS = "*****"; // Put here your Wi-Fi password
const char *PUBLISH_DEVICE_LABEL = "esp32"; // Put here your Device label to which data will be published
const char *PUBLISH_VARIABLE_LABEL = "Temperatura"; // Put here your Variable label to which data will be published
const char *SUBSCRIBE_DEVICE_LABEL = "esp32"; // Replace with the device label to subscribe to
const char *SUBSCRIBE_VARIABLE_LABEL = "Led"; // Replace with the variable label to subscribe to
const int PUBLISH_FREQUENCY = 5000; // Update rate in millisecondsx
unsigned long timer;
uint8_t analogPin = 34; // Pin used to read data from GPIO34 ADC_CH6.
* Auxiliar Functions
void callback(char *topic, byte *payload, unsigned int length)
Serial.print(topic);
Serial.print("] ");
for (int i = 0; i < length; i++)
* Main Functions
void setup()
// ubidots.setDebug(true); // uncomment this to make debug messages available
ubidots.setup();
ubidots.reconnect();
ubidots.subscribeLastValue(SUBSCRIBE_DEVICE_LABEL, SUBSCRIBE_VARIABLE_LABEL); // Insert the device and variable's Labels, respectively
timer = millis();
void loop()
if (!ubidots.connected())
Serial.print("No conexion");
if (millis() - timer > PUBLISH_FREQUENCY) // triggers the routine every 5 seconds
float value = analogRead(analogPin);
ubidots.add(PUBLISH_VARIABLE_LABEL, value); // Insert your variable Labels and the value to be sent
ubidots.publish(PUBLISH_DEVICE_LABEL);
Serial.print("Analog= ");
Serial.println(value);
timer = millis();
ubidots.loop();
