Missing day in Values Table widget
Here’s an interesting one… I’ve setup a values table widget in my dashboard to show daily summaries (max, min, sum). It works fine.
When I set a date range to something like “Last 30 Days”, it shows a maximum of 10 rows (days) at a time.
Note in screenshot the dates are 9/8 to 9/17.
When I click the forward button to move to the next 10 rows, it shows 8/28 to 9/6. For some reason, 9/7 is missing.
I’ve checked the data, 9/7 is complete. I’m able to reproduce this with different date ranges.
Is anyone else seeing this?
Hello @andynad,
Thank you for sharing this and bringing it to our attention.
I’ve been able to reproduce this issue and have reported it to our Development team so that it its further analyzed and fixed as soon as possible.
Please accept our apologies for any inconvenience that this may cause.
Sebastián
Hello @andynad,
Although I was able to reproduce this issue when you reported it, after reviewing it with one of our Developers it doesn’t seem to happen anymore. Could you please confirm that this issue has been solved for you?
Sebastián
Hi Sebastian,
Yes, I’m still able to reproduce the issue. I just made a values table that summarizes maximum and minimum with a sample period of 1 day.
When I select a date range (using quick range) of the past 30 days, the table shows 9/28 - 10/7, the next shows 9/17 - 9/26, and the next is 9/7 - 9/15. In this case, 9/27 and 9/16 are still missing.
If you like, I can send you a direct link to the dashboard.
Hello @andynad ,
Thank you for your response. I’ll try this out again from my side and I’ll give the feedback to the Developer in charge.
I’ll come back as soon as fix this out.
Sebastián
