From a quick look to your code, I believe the use of the Ubidots library isn’t the correct and it’s hard to predict what could be wrong. For example, the line:
int INET = client.ubidotsSubscribe("DACHA","Ttarget");
The ubidotsSubscribe()subscribe method returns a boolean, not an integer. Also, if you’re subscribing using MQTT as the library does, you need to have a callback() function in your code to handle the messages once they arrive from the cloud.
If you are not yet familiar with MQTT or the library, I recommend referring to the below resources first and then attempt developing your own firmware
Hi! Sorry, I just learning C++ (arduino) and for me is complicate to understand some moments, could you explain?
I returned callback() function in to my sketch - nothing has changed, probably some another reason of crush?
I read examples offered by library “UbidotsESPMQTT.h” and did not find another method to get data from ubidots except client.ubidotsSubscribe. Could you advice some another example, i need to get target temp?
@Mamchur please refer to the below article to learn about the use of the library. I recommend to first try out the simple examples therein before adventuring into coding your own firmware, this will give a good grasp of the library methods
To answer your questions:
The code you included before did not contained a callback() function. If you included already that’s fine, but I hardly thing that would the reason causing the code so crash.
You’re correct, client.ubidotsSubscribe is the method to receive data from Ubidots but you need to call it correctly as depicted in the examples of the article.
Please do follow the guide first to make sure you get the introductory examples working.
The Ubidots’ library for the ESP8266 already defines the MQTT server and port in the background. No need to do this manually.
Did you you follow the example in the article previous sent? These example are proven to work and they’re the first step into getting to know the library and how it operates.
Hi David!
probably my skill is to low, but I didn’t succeed in my try to use MQTT protocol. But after reading forum, finally successful made code for HTTP exchange.
Could you help me? I wrote code for http data exchange, but something strange happen:
It’s always correct getting data from slider to device,
but send data to ubidots is strange - once not recorded to device i create on web and used key, but create completely new device, with exactly the similar key! More ower, I took my NodeMCU to remoute house and it’s happened once again!
But today I have a little free time in office and was trying to start my progect to fix issues - surprise, this time data not sending at all, just getting data!
Now that you’ve switched to HTTP, have you seen this example?
It may give you a glimpse of what may be different in your code for sending data. Also, if you want the data to be sent to the same device, you should give a device label in the following line:
bufferSent = ubidots.send("your-label-here");
This will force the data into the same device in Ubidots.
Could you try this out and post back on how it goes?
