[Partially SOLVED] Arduino/Genuino 101, cc3000
I’m trying to send a get value request and it sends me back a compile error, can anyone help with this?:
Arduino: 1.6.9 (Mac OS X), Board: “Arduino/Genuino 101”
WARNING: Spurious .github folder in ‘Adafruit CC3000 Library’ library
In file included from /Users/patt/Documents/Arduino/libraries/Adafruit_CC3000/Adafruit_CC3000.h:28:0,
from /var/folders/pl/j0c2dctn3493pkh06w5lh84r0000gn/T/arduino_modified_sketch_162263/buildtest.ino:30:
/Users/patt/Documents/Arduino/libraries/Adafruit_CC3000/utility/cc3000_common.h:180:15: error: conflicting declaration ‘typedef INT32 time_t’
typedef INT32 time_t;
In file included from /Users/patt/Library/Arduino15/packages/Intel/tools/arc-elf32/1.6.4+1.0/arc-elf32/sys-include/stdio.h:47:0,
from /Users/patt/Library/Arduino15/packages/Intel/hardware/arc32/1.0.5/cores/arduino/Print.h:24,
from /Users/patt/Library/Arduino15/packages/Intel/hardware/arc32/1.0.5/cores/arduino/Stream.h:26,
from /Users/patt/Library/Arduino15/packages/Intel/hardware/arc32/1.0.5/cores/arduino/HardwareSerial.h:24,
from /Users/patt/Library/Arduino15/packages/Intel/hardware/arc32/1.0.5/cores/arduino/Arduino.h:103,
from sketch/buildtest.ino.cpp:1:
/Users/patt/Library/Arduino15/packages/Intel/tools/arc-elf32/1.6.4+1.0/arc-elf32/sys-include/sys/types.h:110:18: error: ‘time_t’ has a previous declaration as ‘typedef long long int time_t’
typedef TIME_T time_t;
/var/folders/pl/j0c2dctn3493pkh06w5lh84r0000gn/T/arduino_modified_sketch_162263/buildtest.ino: In function ‘void setup()’:
/var/folders/pl/j0c2dctn3493pkh06w5lh84r0000gn/T/arduino_modified_sketch_162263/buildtest.ino:46:25: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
#define WLAN_SSID “myquest1811” // cannot be longer than 32 characters!
/var/folders/pl/j0c2dctn3493pkh06w5lh84r0000gn/T/arduino_modified_sketch_162263/buildtest.ino:136:16: note: in expansion of macro ‘WLAN_SSID’
char ssid = WLAN_SSID; / Max 32 chars */
Multiple libraries were found for “Adafruit_CC3000.h”
Used: /Users/patt/Documents/Arduino/libraries/Adafruit_CC3000
Not used: /Users/patt/Documents/Arduino/libraries/Adafruit_CC3000_Library
Not used: /Applications/Arduino.app/Contents/Java/libraries/Adafruit_CC3000_Library
exit status 1
Error compiling for board Arduino/Genuino 101.
Invalid library found in /Applications/Arduino.app/Contents/Java/libraries/CC3000_WiFi_Shield: /Applications/Arduino.app/Contents/Java/libraries/CC3000_WiFi_Shield
This report would have more information with
“Show verbose output during compilation”
option enabled in File -> Preferences.
@bah
You have an error including libraries to your IDE:
exit status 1
You need to fix it to compile the libraries.
how do you fix this?
@descobar3d for that problem the best solution is to delete 2 of these libraries, because the problem is the multiple definitions of adafruit library.
Metavix
